What Intake Manifold
Old Nov 18, 2006 | 04:05 PM
NASTY98TA's Avatar
Default What Intake Manifold
Alright I was going to use a Victor Jr on my 402, F1A setup, but i do not want to
cut the cowl. So I am debating, should I use A LS2 Manifold with a 90MM TB,
Or a LS6 Intake. Ive heard that the gains of a ls6 are better but would that be
the case with a big cube, Blown Application? I would appreciate the feedback
Thanks
Brian
Old Nov 18, 2006 | 05:28 PM
stevieturbo's Avatar
Seems to be a hot topic at the moment....
Here is an interesting example....They say they are using a stock LS6 intake, and stock unported TB...
Doesnt seem to be hampering them.
https://ls1tech.com/forums/forced-induction/571344-pete-craig-raise-bar-again-8-39-163-55-a.html
Old Nov 18, 2006 | 05:58 PM
mike m's Avatar
Im running an ls6 intake. I put an mti billet ported throttle body and lost 1lb of boost and 20 rwhp.
Old Nov 18, 2006 | 08:27 PM
NASTY98TA's Avatar
You lost 1 lb of boost with a LS2? 0r LS6
Old Nov 19, 2006 | 05:21 AM
I switched from an LS6 intake and stock ported TB, to a Victor Jnr/elbow and 85mm TB....
If anything, my boost increased 2-3kpa.
Old Nov 19, 2006 | 08:20 AM
52172's Avatar
I would run an ls6 with stock ported TB look at speed incs twin turbo kit they are just dynoing it put down 1136 rwhp using an ls6 and they say they have swapped a 90/90 on it and they did not gain ANYTHING.
Old Nov 19, 2006 | 10:25 AM
mike m's Avatar
I lost a 1lb adding an mti 78mm throttle body. I always had an ls6 intake on the car.
Old Nov 19, 2006 | 05:20 PM
88GT&69ss's Avatar
BECK Mechanical
I will be running one of becks intakes on my 408 setup. He does some pretty sweet work.
Last edited by 88GT&69ss; Nov 20, 2006 at 10:36 PM. Reason: i believe beck is a sponsor. Maybe you should review the sponsor list smokinhawk.
Old Nov 19, 2006 | 06:00 PM
TINKRD's Avatar
Originally Posted by 88GT&69ss
Intake manifolds
what's the benefit of a sheet metal intake?
Old Nov 19, 2006 | 08:14 PM
NASTY98TA's Avatar
Default Sheet Metal
Im curious about that, has anyone tested a sheetmetal setup compared to a LS6 setup on a blower car?
Old Nov 19, 2006 | 09:35 PM
88GT&69ss's Avatar
Im not totally sure but i believe since its built for you application. You have better plenum volume and runner lengths are designed for your application.
same as on charlie johnsons car on the conley's wall of fame.
check it out
Old Nov 20, 2006 | 10:41 PM
88GT&69ss's Avatar
I also am running victor intakes on both of the mustangs. They have worked great. I know its a totally different intake runner design than a ls1. But seems to work great on boosted applications.
Old Nov 21, 2006 | 12:36 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Maybe state a horsepower goal for a better answer on the best intake.
Old Nov 21, 2006 | 12:55 AM
ninetres's Avatar
run your boost reference after the Tb and walla----no boost loss.
