View Poll Results: When I start my Procharger install should I post all the pictures on here??
Yes
27
96.43%
Hell No
1
3.57%
Voters: 28. You may not vote on this poll
Learn me how to Procharge! Please!!
Old Nov 23, 2006 | 10:48 AM
WAHUSKER's Avatar
I would go with the bigger heads. They should help control detonation at hi boost levels due to the lower comp ratio. If your goal is 1000rwhp, you will need an F series. I hope to hit around 700 with my D, but then I'm not really pushing it. I don't want it to
And the FMIC will be a must at that level too. You may want meth to keep it safe & add a little more hp. And while tuning FI is an art, once you get it dialed in, it's fine. If you're having Bob set it up for you, you shouldn't have any problems. He knows his stuff.
One more opinion, I like iron blocks for boost, but the SLPs had issues a while back. I'd call Scoggin Dickey. The short block I got from them was superbly setup. And get ARP bolts/studs for EVERYTHING!
Old Nov 24, 2006 | 02:32 AM
Gold Phoenix's Avatar
I noticed that no one mentioned that the lower radiator support has to be moved forward to get more clearance for the inlet of the head unit if he wants to install an air filter. I pieced my F1R kit together. I had to buy a SDCE pulley upgrade and F-body bracket because the original was for a 'vette. It came with a Spearco 1500cfm W/A intercooler, water pump, lines, heat exchanger, and a small tank (for a 'vette.) I had to buy more aluminum tubing and silicone couplers along with an ATI Damper.
What cam and intake are you planning on running with? I was going to use a set of PP Stg2 heads, but I was afraid my HP goals would give me head gasket problems. So now I am looking at a set of ported Dart heads from TEA that has the thicker deck. I don't if you could spin a F1R slow enough. The previous owner of the F1R used the factory crank pulley and 4.75" blower pulley. I guess he got by with it. I would build the motor first with the blower, then install it one time in the car.
Old Nov 27, 2006 | 06:56 AM
1Hotbird's Avatar
Can anyone tell me about how much Hp i can make with a 402 iron block about 9:1 Compression, stage 3 heads, a blower cam from EPP, headers, F-1A Procharger, Front intercooler, Better hat for ths F-1A, 8 rib, pully setup, and a Big fuel system.
I'm looking for Rough estamates on HP with and without Metonal Injection!
Also how much boost will I be able to run with and without Metonal?
How can I put "fail safes" on my methonal kit so I don't blow the motor if The lines plug up of the methonal pump fails?
Thanks for any info you can give me!!!
Old Nov 28, 2006 | 06:43 AM
1Hotbird's Avatar
TTT for the morning crew!!
Old Nov 29, 2006 | 04:56 AM
EPP's Avatar
EPP
Smile
800+ rwhp.
It seems to me that Snow Performance offers a system that releases boost if the meth isn't flowing. If memory serves me correctly, it was on page 131 of the last issue of GM High-Tech. Bob
Old Nov 29, 2006 | 06:31 PM
1Hotbird's Avatar
Originally Posted by Exotic Performance Plus
800+ rwhp.
Thanks Bob I see it in the Sept 06 Issue on page 92 and 102!!
Bob do you recomend the Snow Performance Brand?
I called you today looking forward to your call back tommarow!!
Old Dec 1, 2006 | 04:42 AM
EPP's Avatar
EPP
Smile
Bob do you recommend the Snow Performance Brand?
I called you today looking forward to your call back tomorrow!!
I left voice mail messages on several machines, hopefully yours was one of them. If not, please call me back. We've had good results with the Snow Performance brand. Bob
Old Dec 4, 2006 | 07:06 PM
1Hotbird's Avatar
Got in touch with Bob today!! Super Nice Guy!! Even nicer prices on the procharger and other items!! Looking forward to bolting on my go fast parts!!
Old Dec 5, 2006 | 04:35 AM
EPP's Avatar
EPP
Smile
Thanks, I appreciate it! Bob
Old Dec 13, 2006 | 08:26 PM
1Hotbird's Avatar
Bob I recived the parts, they look great!! Can't wait to order more parts!
Old Dec 18, 2006 | 04:41 AM
EPP's Avatar
EPP
Smile
Bob I received the parts, they look great!! Can't wait to order more parts!
Awesome! Thanks! Bob
