Twin Turbo Dyno Video
I guess ya missed post # 9 HUH???
Below..
Post # 9
The customer wanted a T400 because of cost and reliability. It should cruise fine on the hwy with 3.08 gears.
As far as clearancing, the head of the passenger side motor mount bolt had to be ground flush, and a small section of the top of the motor mount bracket had to be clearanced. The GT35R's fit much better. As to which turbos are better, the GT35R's have a 61mm compressor wheel and the PT67's have a 67mm compressor wheel. The 67's should be capable of a bit more power but I won't know until we run a similar combination with the GT35R's.
The turbo system will absolutely not work with the stock K-member.
Looking awsome guys.....
Below..
Post # 9
now dont get confused im speaking in a general sense, not trying to knock speed inc or their products because they do a hell of a job, but that set up should yield a whole lot more than 625 on 93 oct.
The only way to find the true limit is to push it on 93 until it breaks. If you want to donate your engine for testing I'll be happy to find out that limit, but generally our customers would prefer us to stay conservative when pushing nearly 1000 crank horsepower with their brand new combination.
I just wished that HP tuners made a 3-bar SD conversion for '98's.......I'd turn mine up to 20+ PSI.....
Nitrorocket- I prefer to stay conservative enough with boost/timing/octane to stay out of knock alltogether at this HP level. I just don't feel comfortable trying to run alot of boost on 93 octane and relying on the knock sensors to kick it down to a lower octane timing table. (which just tells me it should be running better fuel)
Andy why don't you hold off until tuning it up until around September, let me catch a bit more, I'm over a second slower than you right now.
