Twin Turbo Dyno Video
Old Dec 11, 2006 | 05:37 PM
  #41
BLk01SS's Avatar
That's sweet man, can't wait to get my CAS kit runnin
Old Dec 11, 2006 | 09:48 PM
  #42
eviltwins's Avatar
Originally Posted by LASTLS1
Your forgetting we're on LS1 tech. Everyone wants 1000rwhp on 87 octane and getting 30 mpg!
Just spray 800 hp worth of nitrous with a seperate fuel system into a SOHC civic, done and done
Also one thing you have to consider for a pump gas tune is cylinder pressure and detonation run hand in hand, with torque and cylinder pressure sharing a fairly direct relationship. Make less torque and turn the motor more RPM's and you will make more horsepower before you hit MBTT for your octane.
Old Dec 11, 2006 | 11:12 PM
  #43
LASTLS1's Avatar
6 Second Club Moderator
Yeah Jim would not tune a 93 pump gas combo to the edge and then give it to the customer.
Andy why don't you hold off until tuning it up until around September, let me catch a bit more, I'm over a second slower than you right now.
Your going to be just fine! One more time out to the track and you'll be right there, quit sand bagging!
Old Dec 11, 2006 | 11:15 PM
  #44
Mike00ss's Avatar
Looks great guys.
Old Dec 12, 2006 | 09:29 AM
  #45
CHRISPY's Avatar
Looks awesome guys! Very impressive!
Old Dec 12, 2006 | 08:55 PM
  #46
qqwqeqwrqwqtq's Avatar
Thanks guys. And just an update but the system we had in stock is now spoken for. We'll have another available in approx 1 month. (Need a little more time than usual due to the upcoming holidays).
Old Dec 12, 2006 | 11:47 PM
  #47
Dave95Formula's Avatar
Just curious...what is in your Sportsman 370 Short-Block (rods, pistons, etc) to hold up to this power level? Are the heads studded? Stock size studs? Is the block o-ringed?
Dave
Old Dec 14, 2006 | 08:50 PM
  #48
Dave
It is an Iron 6.0 block, stock crank, eagle rods, Diamond pistons/rings. ARP head studs are used (stock size) along with GM MLS gaskets. The block is not O-ringed.
Old Dec 18, 2006 | 12:33 AM
  #49
Tom@SpeedInc's Avatar
Theirs a 370 sportsman shortblock in stock if anyone wants to get serious
Old Dec 18, 2006 | 12:46 AM
  #50
mahhddgtp's Avatar
PM sent.
In case if anyone is wondering, I'm not looking to grab the last block... I'm just PM'ing for some info about the block
Old Dec 18, 2006 | 01:13 AM
  #51
BOONE's Avatar
Well engineered kit guys, looks great. I would buy it if I was in the market.
Old Dec 18, 2006 | 01:26 AM
  #52
2MuchRiceMakesMeSick's Avatar
great looking kit with great numbers.
Old Dec 26, 2006 | 09:48 AM
  #53
onfire's Avatar
Coal Mining Director
Originally Posted by INTMD8
We recently finished a customer vehicle with our new Twin Turbo street system.
system details- https://ls1tech.com/forums/forced-induction/537009-new-twin-turbo-system-pics.html
video- http://www.ls1speed.com/movies/820tt.wmv
The engine is our 370ci sportsman shortblock, AFR 225 heads, 225/225 113lsa cam, stock throttle body/LS6 intake. T400 trans, 12-bolt rearend w/3.73's (soon to be changed to 3.08's).
This is our new twin turbo system that retains all stock accessories in their original location. Turbos are PT67 P-trim, which as we found are actually physically longer than the GT35R's which caused some clearance issues with the motor mount stands on the K-member. (grinding for clearance was necessary). Dyno runs were also made through a dual 2.5in exhaust exiting at the rear bumper. (it was on the car previously and the customer wanted to keep it).
I tuned it with HP Tuners 3-bar operating system. Injectors are 60lb edge injectors @72psi base pressure.
It made 520rwhp @ 8psi boost and 820rwhp @21psi boost. Pulls were made to 7100rpm. Iat's reached 85 deg at 7,100 and 21psi boost.
All in all we are very pleased with the results considering the cars streetability is not compromised. Should easily be good for 900+rwhp in a 6-speed car.
Jim, did you use the base FP @72psi plus boost referenced the regulator for a total of 94psi ?
Old Dec 26, 2006 | 11:53 AM
  #54
Yes, 93psi to be exact
Old Dec 26, 2006 | 01:54 PM
  #55
No Juice's Avatar
Jim, when is your car going to be up and running again with this kit on it? What motor are you going to put back in it?
Old Dec 26, 2006 | 03:17 PM
  #56
I should have the motor back this week, so it will be running soon.
Stock aluminum block, stock crank, scat I-beams, Diamond pistons (flat top). Still keeping the same truck heads and 216/216 cam.
I'll probably just keep it at around 600rwhp until I can do a rearend and a better clutch. I'm looking forward to the spring as this car will become my daily driver.
Old Dec 26, 2006 | 03:23 PM
  #57
onfire's Avatar
Gotta love Bosch 044's
Old Dec 26, 2006 | 05:34 PM
  #58
BW's Avatar
BW
how much power will it make on 87 octane from sams club?
Old Dec 26, 2006 | 05:46 PM
  #59
SuperZ's Avatar
seriously?????
Old Dec 26, 2006 | 05:58 PM
  #60
Tiago's Avatar
