Lower Compression= Safer??
Old Dec 15, 2006 | 11:14 PM
Snyper's Avatar
Default Lower Compression= Safer??
I plan on running 10psi from the TC76 and I traded my 56CC heads for a set of 62cc heads with safety/longevity of my motor in mind(they flow the same) I would of been around 8.9-9.0:1 and now it should be a little under 8.5:1. I know there will be some power loss but im more concerned with making the motor last longer.
Is lowering the comression say .5-.7 really going to make a difference(engine safetly longevity wise)?
Old Dec 16, 2006 | 02:06 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
It will probably last one more turn of the boost **** than it would at higher compression.(most people who plan on 5psi end up at 15 or 20, you are already planning 10). Seriously, it really does all depend on the components and tune. Boost pressure is orders of magnitude less than detonation pressure.
Old Dec 16, 2006 | 11:53 AM
Snyper's Avatar
well im saying at 10psi/10psi would it really make a difference at the same boost level?
Old Dec 16, 2006 | 12:58 PM
engineermike's Avatar
Yes, at the same boost level it will be safer. However, as gametech implied, you will later realize that you can turn up the boost since the compression is lower and get even more power. Resistance is futile. You will turn it up.
Old Dec 16, 2006 | 03:15 PM
Snyper's Avatar
hahaha so that half of a point will make a difference..thats a good thing then. and no, I wont turn it up. =) I never turned it up on the supra and I was happy.
