Superman09's Twin Turbo Build Thread (Turbo-Zone Twin Kit)
#262
haha, being young i still have a lot of other priorities i need to put first so i can go where i want in life...... but i do want to go fast Keep updated! Wont be much longer.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
#264
i'll get up a bunch more this weekend........ and hopefully a video too
__________________
#266
Yea, Snow and salt FTL. Hopefully its a quick winter. I'll let you know once its running and tuned Jeff. Hows your car coming BTW, havent chatted in a while.
__________________
#268
awesome, well give me a call and i'll come down and help out for sure! I only have school Monday next week so i plan to be working on cars a lot and maybe even get mine to the dyno if its all finished and works right.
__________________
#269
Here are some pics as promised. Got more work done tonight. Car is very close to complete. Tonight we got the oil drain complete, all of the heat wrap now installed, TB drilled for meth nossle, meth line ran, few other things.. All that is left is to run vacuum lines, get a longer hose for some thingamajig that runs to intake, fluids, power the guages/scavenge pump, drill hole in up-pipe for IAT sensor and we are done! Planning to finish up on Tuesday. Here are some pics!
Meth Nossel in
heat wrap
more stuff wrapped
drivers side drain
pass side drain
scavenge pump mounted
been done for a while but never got a pic, where we mounted the meth activation light
another shot
interior all done and clean
meth injection line installed
another angle
up-pipe needs to be drilled
Line Tee'd into Brake Booster for vacuum reference.
Vacuum box that needs to be installed
Battery that needs to be charged due to deciding to die, and hose that we need longer.
need to get power and ground to scavenge pump
Better shot of the scavenge pump and plumbing mounted
Undershot of all the good stuff
Hope you enjoy, should be done real soon as you can tell. Any questions feel free to ask!
Meth Nossel in
heat wrap
more stuff wrapped
drivers side drain
pass side drain
another shot
another angle
__________________
#270
Looks great, I honestly never thought you'd pull the trigger on this stuff, now look at you! Hopefully she puts down some crazy numbers!
I start tuning mine next week, finally time for some boost!
#272
yea, i wont be doing those 3-1 or 4-2 downshifts, its hard to sya it but i am going to drive this carefully to help my stuff last a bit longer. Motor will run off of the .6 bar 8.7 psi WG springs with Meth on a tune from W2W. I'm hoping the motor stays strong so i can add a trans and rear later next summer.
On another note, still need to pick up some 5/8 hydraulic hose for the oil drain as this is just heater hose in there ATM. It may work and probably will for a while, but i want to get some nice hydraulic stuff i dont have to worry about and check 24/7... anyone know where i can get some? Thanks! Just need some to slip over my barbed fittings so no fittings are required. Thanks!
__________________
#273
and some more pics that Frank just sent me from his camera.
Valvesprings...
Car on ground pushed outside to check ground clearance a while ago. This was when everyone was telling me the cold side was too low.... and you were right. This is how it sat... very low. Its tucked up much better now.
Valvesprings...
__________________
#275
#279
The Scavenge pump is a GearStar unit, same pump as the STS one i believe.
As for IAT sensor, there is really no way to get it between the Meth and TB as the meth is IN the TB, haha. We had to mount the meth nossel after the MAF so we were limited to pretty much the TB to put it. So the IAT sensor is just going to have to go into the up-pipe. The only other option would be to also mount the IAT sensor in the TB, but then meth would be dumped all over it, haha.
Thanks Matt, i'll call around for some hose!
__________________
#280
