Superman09's Twin Turbo Build Thread (Turbo-Zone Twin Kit)
Old 02-01-2007 | 04:05 PM
  #381
Stang's Bane's Avatar
Where did you get the polished radiator support?
Old 02-01-2007 | 04:22 PM
  #382
Superman09's Avatar
LS1Tech Sponsor
Thanks for the nice comments again. As for price, not sure yet, havent added anything up yet. As for PCV, have a breather for oil cap and a catch can coming that will be Tee'd in. Not sure on the TB to VC line, you may be right.... i'm going to call up Rich tomorrow and see what he thinks. What are your guys thoughts on deleting the entire set up and venting everything? Good Bad, maybe? haha Thanks
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 02-01-2007 | 04:53 PM
  #383
navymitch12's Avatar
i say delete the whole thing and vent it! that is what i am doing with my car! but you know that just voicing my thoughts! i also would like to hear what people think about capping off the intake and TB and then just vent the crankcase
Old 02-01-2007 | 05:03 PM
  #384
Superman09's Avatar
LS1Tech Sponsor
what are some negatives to venting entire system?
__________________
Old 02-01-2007 | 05:45 PM
  #385
Selki's Avatar
Originally Posted by navymitch12
take them your computer and have them throw the new injectors and a pig rich tune with no timing at all. thats how i got my car from ga to nc
Hey I have a question for ya. I'm in iraq right now but when I get back to I'm going to install TRT's stage 3 kit running 6psi and one of their cams to match. I'm guessing that you had your tune done in NC right? Where did you get it tuned at? I'll be at Ft Bragg and none of the sponsers here are anywhere close. I've posted threads in 4 fourms and this is about as close as I've come to finding someone who might know someone that KNOWS how to tune an LS1 with boost.
Old 02-01-2007 | 05:46 PM
  #386
you have a pm
Old 02-01-2007 | 05:52 PM
  #387
Superman09's Avatar
LS1Tech Sponsor
Turbo-Zone is making me a custom Radiator Support...
__________________
Old 02-01-2007 | 10:30 PM
  #388
Murdock's Avatar
Lots of good info in this thread:
https://ls1tech.com/forums/forced-induction/517372-my-fi-pcv-crank-vac-system.html
Good luck!
Old 02-03-2007 | 07:45 PM
  #389
Superman09's Avatar
LS1Tech Sponsor
ok thanks, here's a little ms paint i did. Thinking now easiest and best option is venting entire system. Give me some input please, thanks!
__________________
Old 02-03-2007 | 09:26 PM
  #390
onfire's Avatar
Coal Mining Director
I've got the back two valve cover ports y'd together and then to a port in my air cleaner pipe.....so when I'm under boost it puts a vac pull on those two back ports.
PCV line goes to a one way valve then a catch can (not vented) then to a pcv valve then to the manifold port behind the tb.
My TB port between the blade and the airfilter is plugged.
Old 02-03-2007 | 09:28 PM
  #391
Superman09's Avatar
LS1Tech Sponsor
sounds like another good set up.... what are your thoughts on the set up above?
__________________
Old 02-03-2007 | 09:34 PM
  #392
onfire's Avatar
I don't see where the green line accomplishes anything If I understand it. Basically, it's connecting both valve covers together via a catch can. Won't really move any air in either direction.
Old 02-03-2007 | 09:37 PM
  #393
onfire's Avatar
Except it will act as a dual vent since the catchcan is vented.
You'll small some oil fumes that way but it will vent the crankcase .
Old 02-03-2007 | 09:39 PM
  #394
Superman09's Avatar
LS1Tech Sponsor
yea, this set up vents entire crankcase and wont get any oil into the intake.... would like some more input please as i have to set up my PCV soon so i can hit the dyno!
__________________
Old 02-03-2007 | 09:55 PM
  #395
me and superman were talking about this and what his little pic shows is what i planned on running, i know there are better ways to suck the air out with a little vacume but then you always stand the chance of oil in the intake.
Old 02-03-2007 | 11:48 PM
  #396
DanaliHD's Avatar
jonny, whatever you do, don't mount the catch can in the same spot mine was mounted. you could die. im not at all joking. i drove about 10 miles today and my eyes stared wattering and i could hardly breathe. I got out and noticed there was exhaust fumes coming out the top of the catch can and going directly into the cab of the truck.
I had to re route the hose temporarily. i can still smell fumes on myself and that was 6hrs ago or so. use extreme caution please.
Old 02-04-2007 | 08:51 AM
  #397
Superman09's Avatar
LS1Tech Sponsor
dang, well mine is going to but up front much more where the AC condensor used to be. Thanks for the input Dan, really appreciate it and best of luck with your truck!
__________________
Old 02-05-2007 | 08:58 AM
  #398
Superman09's Avatar
LS1Tech Sponsor
Well i just talked with Rich who will be tuning the car and he said that setting up the PCV this way should be fine so i think i'm going to go for it... any last comments/suggestions on it?
__________________
Old 02-05-2007 | 09:19 AM
  #399
JoeliusZ28's Avatar
do it to it jonny!
Old 02-05-2007 | 01:08 PM
  #400
obZidian's Avatar
OMG! thats crazy... first time i hear of that... gotta look into that...
Quick Reply: Superman09's Twin Turbo Build Thread (Turbo-Zone Twin Kit)
