Anyone ever regret going with a procharger?
Old Dec 22, 2006 | 06:32 PM
onefastss223's Avatar
My only regret is not having the D1SC sooner. Not to say the P1 doesnt make great power but the D1 is the better choice for future upgrades, boost envy, etc...
Old Dec 23, 2006 | 05:45 AM
EPP's Avatar
EPP
Smile
Originally Posted by TNTramair
may be a dumb question but....will the stock plastic covers still fit if i wanted to put them back on???
I believe they will. Bob
Old Dec 23, 2006 | 08:18 PM
frcefed98's Avatar
LOL I'm regretting the sale of my old procharger set up to kp everyday.....damn turbo's..
J
Old Dec 23, 2006 | 08:58 PM
kp's Avatar
kp
I have had 3 different procharger setups on three different cars and I dont regret any of them. Never had one issue out of a head unit and they have always performed as expected or better, cant beat that..
Old Dec 23, 2006 | 09:15 PM
2000LS1TA's Avatar
Can't wait, mine is going on this winter
Old Dec 28, 2006 | 12:16 AM
BLASTER's Avatar
Thanks guys. Appreciate the feedback.
How is the tuning? Is it any more difficult to tune than anything else? Do I need to fiddle with it after every season?
I am planning to go with the F1A but I need to set it and forget it for a while. I won't be building a motor to support the real power so I'll want to saftely stay around the 550-575 mark on the stock shortblock for a while.
Old Dec 28, 2006 | 05:50 AM
EPP's Avatar
EPP
Smile
No, the tuning isn't really any harder for someone experienced with forced induction tuning. Once the tune is done, that is it, no need to fiddle with it unless you alter the boost level. Bob
Old Dec 28, 2006 | 06:50 AM
Country Boy's Avatar
Senior Member
If I had to do it all again, I would have gone with a D1SC Procharger from EPP. This turbo **** if for the birds. 50lbs of **** in a 5lb bag.
Old Dec 28, 2006 | 09:34 AM
Packy's Avatar
I hear that! Maybe soon I will get an upgrade!
Old Dec 28, 2006 | 09:44 AM
My2kz28's Avatar
I love my d1sc setup! With mods in sig, and 8 psi instead of 7, i put down 446 rwhp and 422 rwtq...not bad for a bolt on lt1...ive added pacesetter long tubes and lanes true duals, and will be adding a blower cam soon, so i should be over that 500 mark...but overall, i like the drivability you get with centrifugals.
Old Dec 28, 2006 | 07:37 PM
mikes99corvette's Avatar
Default ProCharger
I have a Procharger on my C5 and really like it...A&A& has always taken care of me!
Old Dec 29, 2006 | 09:58 PM
  #32
mdhmi's Avatar
I ditched my D-1SC for a twin turbo kit. No belt issues with the turbos!
Old Dec 29, 2006 | 10:44 PM
  #33
BLASTER's Avatar
Care to elaborate on the belt issues you had ?
Old Dec 30, 2006 | 12:46 AM
  #34
mdhmi's Avatar
Started with chucking belts. Got everything aligned then started ripping belts in half. Broke a PS idler/tensioner thingie. It's always something with a blower as you over stress everything that rides on the belt.
What's funny is the guy who bought my old kit has had great success with it. Maybe the stars and the moon weren't aligned properly when my kit was installed.
Blowers are capable of working, but I think they are far more trouble than they are worth. Start with turbos and be done with it. Just my .02.
Old Dec 30, 2006 | 06:50 AM
  #35
Tonner's Avatar
Good to see you all happy with the Procharger
Old Dec 30, 2006 | 03:37 PM
  #36
B18CYA's Avatar
what kinda problems are you having?
this thread came at a perfect time just as i was planning my truck mani t76 custom kit.
Old Dec 30, 2006 | 04:13 PM
  #37
Senior Member
Like I said, 50lbs of **** in a 5lb bag. There just isnt enough room in our cars to do it all right and not seriously modify things. For someone with a lot of time and money and more energy than me, its not bad. Its also a never ending money pit. Ive mented 2 motor mounts (poly), had to buy enough heat wraping to cover the whole car, the wastegate is too small (PTS kit), Im melting/ burning through the turbo blanket, etc, etc, etc....
If you custom make your own kit, then it wont be as bad, but to get both exhaust to the front, and then to the back while keeping good ground clearence is a good challenge. Id rather have a D1, headers and still make 700 with no problems and less parts.
Old Dec 30, 2006 | 04:43 PM
  #38
frcefed98's Avatar
Old Dec 30, 2006 | 10:00 PM
  #39
98redformula's Avatar
I am very happy with my D-1SC f-body kit from EPP. The only issue that I have had is with water being sucked into the intake when it rained. This issue may be particularly related to 98 firebirds because of the location of the turn signal lights and foglights (right in front of the air filter for the procharger kit). As I drove, the air and rain would flow through the holes just above the lights and drench the air filter. I eventually enclosed the air filter in a section of aluminum air duct to prevent the problem. It is not the prettiest solution, but I have not had an issue with the rain again. Hopefully, this will prevent somebody else from learning the hard way like I did.
Also, FYI, if you go with a f-body procharger kit, I would recommend getting the welded air plenum as my plastic one did not hold the pressure.
Regards,
98redformula
Old Jan 12, 2007 | 03:31 AM
  #40
Tonner's Avatar
Does anyone Know a Name at ATI,to talk to about Procharger problems? warranty etc, I have two new F1s with issues.
