F1-C is here...
Whats your injectors DC? KP just ran his 72lbs to 95% too so I just dont see them keeping up with this Combo.
Yes im running a hot wire to the pumps... I was running the 72lbs at 70-80psi of FP and it showed 95% DC around 5K RPM. The thing is... we are running 14 degrees of timing and 11.0 AF and the car seem to want more timing. If we put race fuel and 4 degrees of timing running around 12.0 or so... its game over for these injectors below 5k RPM. There is low to mid 800rwhp and low to mid 700rwtq in this setup on a mustang dyno, but we dont have the fuel or clutch to support it I guess.
Oh well back to the drawing board.
Interesting.... Im going to pull the tranny out today and check that out.
Thanks
Paul
If I remember correctly it has 74K max impeller speed and F1-C on it. It is a 5.4 step up ratio though.
anyway good luck with car it will be a beaSSt
Textraila service is top notch. They are sending us a whole new clutch kit. We have another new Textraila on the car now and i was driving it all day long to break it in.
Now the car is going on the dyno as I type this now..... oh yes its 11:24pm now lol.. PRAY with me that the clutch will hold.
I guess we are done for now until i drop a TH400 in it and call it a day. I will also have to get 96lbs injectors with either a box or BS3 because the 72lbs were running around 90% at 5500RPM or so. I will most likely need another bosch pump due to slight drop in fuel pressure.
I have ran both the 72lb RC and 60lb motorons and the hi impedence 72s dont really flow a whole bunch more up top then the 60s. These 75lb delphi low impedence injectors are around 20% less duty cycle then the RC 72s, same fuel system. Maybe it was just me but I didnt have a lot of luck with the converter boxes.
