F1-C is here...
Old Jan 16, 2007 | 02:23 PM
  #61
GrannySShifting's Avatar
We found about 10-13% more duty cycle to go. not enough
What box and problems did you have KP?
Old Jan 16, 2007 | 02:26 PM
  #62
Originally Posted by BLASTER
So I guess htis is the limit for the 60s in terms of power...
Sorry for all the questions. Trying to learn and tailor my expectation if I go prochager. Thinking about the same setup and as you but with an F1A. Dind't realize that the next up on the injectors would be difficult to tune and going with BIG STUFF wasn't in my future plans.
Thanks
Just do a F1C and be done with it. Not hard to do a secod time around, just cover al bases ahead of time
Old Jan 16, 2007 | 02:36 PM
  #63
Originally Posted by DJ's99SS
Get with Textralia on the problem...they have great customer support. I was using their twin disc but since went to the Triple. So far so good after some machining issues we had to address...and yes I believe your correct. They are RC 72 but flow 750cc's at 43.5lbs of FP. Not sure why your seeing such high DC with these...? Have you tried a volt booster or similar product to help? I'm using the Casper Electronics V-Plus volt booster. I'm at 18psi with zero problems with the injectors keeping up...
What kind fo hp on what dyno? What dutycycle and WOT fuel pressure.
Old Jan 16, 2007 | 02:52 PM
  #64
MrDude_1's Avatar
Clutches do not belong on pool tables.
im going to have to confiscate that pool table until you learn how to treat it nice.
(nice clutch and pool table )
Old Jan 16, 2007 | 02:56 PM
  #65
kp's Avatar
kp
I could never get the car to idle right or be real clean in the low/mid RPM range. I would put the hi impedence injectors back in and it was fine. So I tried a different one, it idled fine but the a/f was doing screwt things at high RPM so I sent it bak and they sent me a new one so I just sold it and did the BS3. Got tired of soldering wires and wondering if it would work..
Old Jan 16, 2007 | 06:27 PM
  #66
BLASTER's Avatar
no thanks. I know my limits. With all the clutch, injector, & t56 issues i see happening here @ this power level makes me think a D1 would suite me just fine.
You guys are scaring me back to reality
good luck
Old Jan 16, 2007 | 08:35 PM
  #67
Posi12Bolt's Avatar
Originally Posted by TrakDay
I swaped from a D1SC to an F1C on my GTO and it was a retarded difference!
I don't really know why... but that made me laugh out loud at work...ooops..
Old Jan 16, 2007 | 10:22 PM
  #68
DJ's Z's Avatar
I'll have to break out some notes and figures. Can't remember "exactly" where everything was at. We did most of the WOT tuning in "real world" driving. Only checked a few things on the dyno...I'll see what I can find for you in my pile of misc papers on the build.
From what I remeber I was at 880RWHP blowing through a Spec 5 clutch on a Dyno Jet Dyno. Did some pulls on a Mustang Dyno with the same clutch issues. Was around 788RWHP on the Mustang Dyno...Fuel pressure is set at 58psi base with vaccum line disconnected from FPR and boost ref 1:1. I believe I'm at 62psi with line hook up at idle. Running dual 340 intank Walbros. Second pump comes on at 7psi of boost. I want to say DC was around 86% at WOT. 7200RPMS / 18lbs of boost. I'm also running a Casper Electronics volt blaster...
Old Jan 16, 2007 | 10:30 PM
  #69
DJ's Z's Avatar
LOL...was as good a place as any to grab a few shots at the time...
Old Jan 17, 2007 | 02:01 AM
  #70
SRZ's Avatar
SRZ
Originally Posted by kp
heh, you will find alot more weak parts along the way
I have ran both the 72lb RC and 60lb motorons and the hi impedence 72s dont really flow a whole bunch more up top then the 60s. These 75lb delphi low impedence injectors are around 20% less duty cycle then the RC 72s, same fuel system. Maybe it was just me but I didnt have a lot of luck with the converter boxes.
That's interesting KP as I have the hi impedance RC 72's but no converter box just the XFI. Thinking of going low 83's but 1st I have to see how these injectors will do.
Old Jan 17, 2007 | 10:36 AM
  #71
kp's Avatar
kp
The 72s worked fine (not trying to talk anyone out of using them), just didnt seem to really flow a lot more the the 60s in my case. Some guys have used them with success but I dont know how many compared them directly to the 60's. I really got tired of all the band aid approaches of getting more fuel, with the same pump/pressure I went from 99% DC using 60/57s to 95% DC using the 72s to 80% using the Delphi 75lb low Z iinjector running similar boost/hp and a/f.
Old Jan 19, 2007 | 02:39 PM
  #72
Ponyhntr's Avatar
Originally Posted by LSs1Power
The HKS fits perfectly with plenty of space left for a thicker radiator. Here are some pics
Where did you get this filter, and do you have the part number?
Old Jan 19, 2007 | 04:36 PM
  #73
LSs1Power's Avatar
Its the only 100mm filter HKS have. It come in Green or Yellow color and they are the same.
