Stock block done!!!!!!!!!!!!
Old Dec 24, 2006 | 11:17 AM
lcvette's Avatar
IF, the block and piece are prepped properly and completely clean and the welder knows how to use his machine it will hold just fine, however if you a skeptic, perhaps some support braces can be added to give some extra holding power to those weak little bosses or have some block aluminum welded in place and redrill new holes for the starter bolts with steel thread inserts, I would not go through the trouble of swapping blocks unless it was part of a previously laid game plan and this is a good excuse to go forward.
welding is STRONG usually the weld is stronger then the surrounding metal and if it breaks it will break at a new joint or location due to the weld being superior in strength. Just find a welder who has experience welding CAST materials as the prep work will be KEY, a guy who rolls his machine out and attempts to just go at it is going to fail at fixing this properly.
Chris
Old Dec 24, 2006 | 11:20 PM
DeltaT's Avatar
I agree with lcvette - weld it up right and fuggetaboudit...
Jim
Old Dec 25, 2006 | 12:19 AM
FastKat's Avatar
Take it to a welder that has a really really good reputation... I'd shop around and only go with someone that's top notch... don't just pick someone out of the phone book. I'm pretty sure they'll also want to leave a little extra material in there so you have something to drill and tap.
Old Dec 26, 2006 | 11:53 AM
MawneeC5's Avatar
Weld it. Hell...if the tabs arent strong enough welded(they should be) why not just weld the damn starter to the block? Otherwise the block is trash anyway right ?
Not that I'm a "just make it work" mechanic....but I cant see tossing a whole block because of a couple of little tabs. Its like throwing away a car because it has a flat.
Old Dec 26, 2006 | 12:33 PM
AustinL911's Avatar
In the event that it does continue to break off. Do us all a favor and see how much boost a stock motor can take....hehehe.
Old Dec 26, 2006 | 01:44 PM
hellbents10's Avatar
LS1Tech Sponsor
Seen it before, fixed and works fine, just have to have a really good welder look at it.
Old Dec 26, 2006 | 08:58 PM
DMH Fabrication's Avatar
like everyone else said... weld it. Belvel the edges a little if you can before welding it. The hardest part about alum, it getting it clean.
Old Dec 27, 2006 | 11:30 AM
ALL UC2's Avatar
if you dont know how to weld aluminum, find someone that does and fix that bitch. if welded right it should be just as strong as it was before.
Old Dec 27, 2006 | 11:43 AM
fullthrottledan's Avatar
Originally Posted by tirefryin_s10
weld it up .... ill try and find the picture later i have of a top fuel motor laying on the ground and all you can see is about 3x3" squares that were busted out then welded back in like im talking this things been stitched all over and still goin strong.... jesus all it does it hold the starter on.........whats the worst that happens you get it welded and then it breaks again ???
which car??
we weld our fuel blocks all the time. pan rails, torched decks, only thing that we dont do is weld up a cracked main. once it cracks there, the block is done. you will be fine welding that up.
Old Dec 28, 2006 | 11:30 PM
ninetres's Avatar
Thanks for the advice. My friend/mechanic is going to give it a whirl welding it up. He is a VERY skilled welder and if it can be welded and fixed.....he can do it.
I'll keep everyone posted.
Old Dec 28, 2006 | 11:54 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Good choice and good luck. Let us know how it turns out.
Old Dec 28, 2006 | 11:57 PM
  #32
ninetres's Avatar
Will do. A 370 with all the goodies would have been nice....but expensive. Plus I have a TON of parts just waiting to be installed:
rossler TH400/stall
fully loaded 9"
all kinds off suspension goodies
LL/abs delete
etc
So it will be nice if it can be fixed, and I can have my ride back with all the new goodies by early next week!
Old Dec 29, 2006 | 08:59 AM
  #33
tirefryin_s10's Avatar
not sure who's car the motor belonged to but it was laying in the parking lot at the rocky mountain nationals held here in edmonton every year looked to me like they just welded it back up and pounded another sleeve in it ready to rock again
Old Dec 29, 2006 | 09:07 AM
  #34
SUPER DAVES Z's Avatar
Good choice! As most have said, weld it and forget it! My block did the same thing when I hydro locked it. The welds worked great!
Good luck with the new build!
Old Dec 29, 2006 | 09:13 AM
  #35
brad8266's Avatar
I think I was boostin so hard even the starter was doin' 10 psi
Sig material
Old Dec 29, 2006 | 07:01 PM
  #36
Mr_president's Avatar
upDATE!!
SEAN (NINETRES)WENT TO GO START HIS CAR AND IT WONT TURN OVER, I THINK ITS HYDROLOCKED , ALL WE HAVE TO DO IS PULL OUT THE PLUGS AND CRANK IT OVER A FEW TIMES RIGHT, SORRY I DIDNT READ THE HOLE THREAD.
Old Dec 29, 2006 | 09:43 PM
  #37
ninetres's Avatar
So yea......tried to push start my car about 3 or 4 times, wasn't happening. Also tried to push it while it was in 6th gear and it wouldn't budge. I don't get it. I don't see how it could be hydro locked. The last time I drove it, it was POURING, but I never went through the smallest puddle. It was driving fine and I parked at my girl's house. Later that night when I went to start it......it just made a big noise on the first crank, and then I could hear the starter spinning freely.
Had it towed to my buddies house who does all my mechanic work that's over my head. We'll see.
Old Dec 29, 2006 | 10:40 PM
  #38
Snyper's Avatar
my friend had this problem, welded his block and it works just fine. I think youll be fine.
Old Dec 30, 2006 | 07:30 PM
  #39
Update! seans block is completely hydro locked! pulled the 8th plug and a huge puddle of water came out....then we tried turning it and it would not....
Old Dec 30, 2006 | 07:38 PM
  #40
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Hydraulic'd the block? That doesn't just happen.
Yup, I have seen that before, in 2000.
