Front Mount and IAT sensor
Old Jan 8, 2007 | 12:10 PM
mcmillion's Avatar
Default Front Mount and IAT sensor
Guys running front mounts. The shop that installed my turbo just left the IAT sensor dangling. Did you guys eliminate it or remount it? If so where did you put it?
thanks
Old Jan 8, 2007 | 12:15 PM
trtturbo's Avatar
you need it.
Old Jan 8, 2007 | 12:28 PM
98turbls1's Avatar
Is there a bung for it or did they not put one in at all??? You want it kind of where the stock one would be...
Old Jan 8, 2007 | 12:52 PM
YellowToy/A's Avatar
I would put it just after the intercooler.
Old Jan 8, 2007 | 02:01 PM
ddnspider's Avatar
you cant eliminate it.Just find a pipe after the FMIC and drill a hole big enough to squeeze the rubber grommet in and stick the sensor in there.
Old Jan 8, 2007 | 03:22 PM
RW99's Avatar
Consider a position just post throttle body, especially if you're injecting methanol. That way you get the most meaningful measurement of IAT as your motor sees the incoming charge, and you'll also be able to easily track your IATs under methanol... to see how well you're cooling.
Old Jan 8, 2007 | 04:38 PM
Jake@EPP's Avatar
We weld in a 3/8's bung into the charge pipe before MAF, and use a grand national AIT (same one as ATI). Its there for a reason.
Old Jan 8, 2007 | 04:46 PM
ls1charged's Avatar
why is everyone welding stuff to the charge pipes?the factory setup works perfectly so long as you drill a hole thats the right size.and i agree M4 Maf
Old Jan 8, 2007 | 06:59 PM
SSilverSSurfer's Avatar
i have mine in pretty much the same spot as it was stock,
Old Jan 8, 2007 | 07:17 PM
Country Boy's Avatar
Senior Member
Thats what I did. Ive pushed 15lbs and its still there.
Old Jan 8, 2007 | 07:22 PM
pdanrichey's Avatar
I have a hole drilled in my charge pipe for one. I would say..."YOU SHOULD HAVE IT!!!" But, that's just my simple opinion.
Old Jan 8, 2007 | 11:01 PM
Jammer's Avatar
Im pretty sure the C5 Z06 Maf has one built into it...clean! Thats what I had before I went SD. Just an otion..plus its 85mm.
