Victor Jr Manifold vs. LS6 intake
Originally Posted by pwrtrip75
i have one on my 5.3 w/ a 224/224 .580/.580 112 cam, its like driving a 200hp car around off boost. With the stock cam it was pretty snappy off idle. I think my cam selection sucks.
Thanks - Ron
It says somewhere on the paperwork with the Edelbrock the thread size...
I think it was 3/8NPT ??
As for no 2....
You can connect any vac/boost items you want to it. Be it a guage, map sensor, FPR, whatever.
I just used ot for my BOV's and used driled a couple of new fittings in the alloy block on the intake elbow for FPR and boost guage, and map sensor.
As for no 2....
As for no 2....
As for no 2....
#1- It is a 3/8 NPT fitting
#2- Works perfect for your MAP sensor
I'm doing the same thing as you, drilling the back of the elbow for a threaded IAT, BOV and WG. Boost guage will tie into the brake booster fitting.
Originally Posted by JMBLOWNWS6
Ok Mike Ill send you my cam specs,Head flow numbers and the intake and you do the porting.
Originally Posted by 1INSANEGTO
Where the hell is that big line going brake booster?
Where did you pick up those other 90's? Local hardware store?
Although I dont think Ive come across a booster yet where boost has been a problem.
The 90's were soruced from a local air tool shop. They are just simple pneumatic fittings. Similar to the fittinges used on Snow meth kits.
Hose just pushes in, easy to remove, and rated to something like 10 bar.
#33
