F1A cons on a 347?
I'd be looking to you and Bod to help guide me in what I would need. Is there any way to calculate (or does anyone have an idea) with the 5" where 9psi of boost would be in the RPM ?
I am assuming the thread poster meant stock block. If so i am in the same boat as she/he.
My stock block has low milage so I want to roll with it for a long while before getting a forge one. Id go with the D1 but figures if I am going with a new engine it will be 400+ and read you want an Fseries for that.
Thanks
As for CI, a d1sc will work on a low 400ci motor but it will be running out of breath. If you go this route, meth and a fmic is required to keep the soaring IAT's down.
One possible route is to get a d1sc, then sell it when you get the new motor going. The d1sc usualy sells alot better then a p1 due to its power range.
Has anyone done this yet? I am considering it but no good results from searching.
Also, what is the smallest crank pulley I can get to keep the boost down along with the 5" blower pulley?
I have a 235/243 @ 110+2 cam so that should help bleed some boost too.
F1A with a 7.25/4" pulley on a 347 with a 232/242 114 cam a couple years ago:
http://videos.streetfire.net/video/8...ger_710762.htm
im not sure but i would say u will be well in the teens on boost if not pushing on 20 with a bone stock engine min. cam
Its really hard to say what the boost will be until you try it, you can always restrict the inlet. I dont think you will get it to 8psi with a 5" pulley.
I'll be giving you a call once I pick up my new project
If for any reason you think you need to grind on the bracket then you are using the wrong shim size between the head unit and the supercharger pulley. Any questions on this please contact Procharger before cutting away material, they can provide the two .1" shims (total of .2" between pulley and blower) to put the pulley in the correct spot to clear the bracket and line up correctly with the other pulleys in the system.
