best junk yard engine
Old Jan 11, 2007 | 11:26 AM
tt69camaro's Avatar
Default best junk yard engine
I am wondering what would be the best engine to buy and what vehicle it comes out of. It's for a budget build big single turbo car? I'm thinking a 6 liter truck engine. Any insight would be helpful as well as what stock engine limitations are.
Old Jan 11, 2007 | 11:27 AM
Boostaholic's Avatar
budget turbo build with junk yard engine sounds like a bad idea.
Old Jan 11, 2007 | 11:44 AM
tt69camaro's Avatar
OK lets forget the budget angle (Nothing I build is ever cheap anyway). I have a car with no engine and want to progessively build it into a turbo engine. Where do I start?
What internals have to change and at what power level?
Old Jan 11, 2007 | 11:47 AM
Hennytime's Avatar
best low budget is an sbc35 carbed out of just about anything from the 60's-early 80's you an get them complete from most junkyards for under 400 bucks
Old Jan 11, 2007 | 11:51 AM
98turbls1's Avatar
Stock block is reasonably good for 550-600rwhp if you have a reliable tune on it...Above that the rods start to go and you may as well just change the pistons...As far as rods goes Eagle and Compstar are the two best contendors...Pistons I would choose Diamond, Wiseco, or possibly Mahle... Keep the stock crank in there and just have it polished...They are good to well over 850rwhp...That's 1000fwhp...What are your goals?? Et's, power, price???
Old Jan 11, 2007 | 12:09 PM
tt69camaro's Avatar
I will probably have to change cam, rods and pistons. 800+ hp is the goal. I want to build my ol lady a toy. (I wont let her drive mine.) Is the 6.0 truck engine a good place to start or should I try and find an LS2 or something else? How are the heads/ intake?
Old Jan 11, 2007 | 12:18 PM
98turbls1's Avatar
The 6.0 truck block is a perfect place to start....They are rigid and done right can handle twice as much hp you're looking to get... As for the heads you can definitely use some LQ9 heads and just get them worked over a bit...Definitely upgrade the valve springs... I would go with an LS6 intake...
Old Jan 11, 2007 | 12:27 PM
98Z28MASS's Avatar
+1 for the iron 6.0 liter truck block! Also I would say to go with a set of patriot stage 3 6.0 liter heads, toss in an ls6 or GT2-3 cam, and spend the rest of the money on some badass internals as you will need them with 800+ hp.
Old Jan 11, 2007 | 12:31 PM
pwrtrip75's Avatar
my 5.3 baught from LKQ complete for $500. swap on 6.0 heads and 8.6:1 compression, perfect turbo engine for cheap. holding 15psi and running strong.
Old Jan 11, 2007 | 12:51 PM
Project GatTagO's Avatar
Depends what your goals are...
Andrew
Old Jan 11, 2007 | 12:59 PM
tt69camaro's Avatar
what kind of power does your 5.3 make? Interesting idea!
Old Jan 11, 2007 | 01:12 PM
My build is in process. However I will be surprise if it does not make around 500RWHP with mostly stock parts.
Andrew
Old Jan 11, 2007 | 01:45 PM
tt69camaro's Avatar
My buddy owns a junk yard. He said to pick out what I want. So what years/models trucks should I be looking in for my 6.0L? Are all the 6 liter heads/ blocks the same? I would also like to use the stock exhaust manifolds reversed.
Old Jan 11, 2007 | 01:59 PM
98turbls1's Avatar
no!!! 99 6.0l blocks have iron heads... I would go with a '00 and up... Just make sure that you get everything checked out if and when you do build it...Take it to a reputable builder and get it magnafluxed and a hi-temp dipped to check for cracks and get it completely clean... Do spend money on getting all of the required machining... Whatever you do don't skimp on the critical stuff... Have fun!!!
Old Jan 11, 2007 | 02:39 PM
tt69camaro's Avatar
Thanks for your input 98turbls1
