Looking for F-body D1 Installation Instructions
There are no PDF versions that I know of at this time.
Just call up ProCharger and have them send you a copy.
They come pretty quick in the mail.
EA
When installing the ATI balancer I'd suggest you lightly coat the ID with spark plug anti-seize. Preheat an oven to 300 degrees. Place the balancer in the preheated oven for 15-20 min. Using good gloves or oven mitts start the balancer straight on the crankshaft and then draw it on with whatever tool you have. The stock bolt will work, but is too short right at first. You can get a longer one to use for initial install. The balancer will draw right on if you heat it up without much effort.
As far as the torque to yield procedure, that's another story. I hope its a stick with a working parking brake. Good luck.
