ATI Damper
Old Jan 13, 2007 | 01:17 PM
Whitez406's Avatar
Default ATI Damper
Wheres the cheapest place to buy one? When using the SDCE setup can you run the 10% underdrive or must you use standard dampner?
Old Jan 13, 2007 | 01:46 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Bob at EPP has them. You can use either one. I stuck with the standard diameter.
Old Jan 13, 2007 | 02:06 PM
Jake@EPP's Avatar
The balancer is $449.99 from us.
Old Jan 13, 2007 | 02:54 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
"Damper" as spelled on their website: http://www.atiperformanceproducts.co...pers/index.htm
Old Jan 13, 2007 | 06:03 PM
Whitez406's Avatar
Which is better 10% or standard?
Old Jan 13, 2007 | 06:28 PM
98turbls1's Avatar
Well it really depends...if you're running a stock or stripped car without a huge stereo system then I'd go with the 10% underdrive...but if you have something that your lights are already dimming then definitely don't go with one... I noticed a sizable difference when I put mine on...Well I also took the AC belt off too at the same time... It was a good SOP feel if you know what I mean... =)
Old Jan 13, 2007 | 07:26 PM
TryingT/A's Avatar
What are the point of these? Sorry for the stupid question, but a procharger is in my future.
Old Jan 13, 2007 | 08:03 PM
BIG BAD BLACKSS's Avatar
If you get an 8 rib pulley system the ATI (not ati procharger, different ati) is mandatory. The 8 rib crank pulley will not work on the stock damper.
I honestly cannot remember if i got the 10% underdrive or not, been a couple months since i ordered it!
Old Jan 13, 2007 | 08:36 PM
EPP's Avatar
EPP
The ATI ProCharger eight rib pulley gets bolted to the balancer. The factory balancer doesn't have the provisions for this, and the only brand that we have found to fit the ProCharger pulley is by the harmonic balancer company, ATI Performance Products. Bob
