4" downpipe vs. K-member clearance..
https://ls1tech.com/forums/forced-induction/508764-truck-manifold-turbo-set-up-faq-s.html
had to grind the AC mounts down and a couple of places on the kmember.
I am starting to 2nd guess my turbo placement........originally I wanted it in the battery location. Starting to wonder if a center or lower mounting might be better....
Any pros and cons either way?
Looking forward to seeing the white machine. I used oval and went under.... I wouldnt do it that way again though.
Maybe it is the UMI k member??? If it can be done...he will figure it out. He is a master welder and very skilled at building mandrel systems.
Another idea that crossed my mind was; once the exhaust leaves the compressor housing as 4", why can't I split it back to two 2-2.5" pipes and runs duals back out under the motor mounts???
The radiator support is coming out already but that is not the clearance I am looking for.
also it makes it easier and yields better clearance as you dont have to go under the tranny to route the exhaust to the back.
Now I just need to decide if I am going to mount the turbo in the center or off by the battery......
Those of you that have center mount turbos......how are you supporting the dead weight?
here is a shot of the new mount idea;
then you still have the problem of crossing over the tranny (clearance problems) to get to the back
Getting 4" off the exhaust housing and at least 4' back is a big plus vs. 3" all the way back. If I need to do some reducing near the tranny I might not sweat it. Don't really plan on getting over the axle either..
