Boost Ref FP Regulator of Choice?
Old Jan 17, 2007 | 02:34 PM
ss1's Avatar
ss1
Default Boost Ref FP Regulator of Choice?
Just wondering what fuel pressure regulators (boost referenced) you guys are running with success? I'm just looking to get one with two inlet ports -6an, one return -6an, and a gauge port.
I've been looking around and see that some people have had issues with Aeromotive and others say they work fine. I know Nasty uses Fuelab regulators on some of his setups but haven't found too much info here on them. I know Magnafuel is in the mix too.
So, what are you guys running/recommend? Pros/cons?
Old Jan 17, 2007 | 02:35 PM
Country Boy's Avatar
Senior Member
I have a Magnafuel.
Old Jan 17, 2007 | 02:59 PM
sonicbaloo's Avatar
We run Aeromotive FP regulators on our high HP FI motors.
Chad
Old Jan 17, 2007 | 03:07 PM
MIGHTYMOUSE's Avatar
get the CAS one that speed inc. sells
NA$TY-TA's Avatar
Aeromotive Pro Series here......
Old Jan 17, 2007 | 03:23 PM
ABeasst's Avatar
Aeromotive dual -10 inlets -6 outlet that is transitioned into a -8 line.
Old Jan 17, 2007 | 03:26 PM
SSilverSSurfer's Avatar
the only one that speed inc had on their website is the prof. products powerflo and i went ahead and ordered it. didnt see the CAS one
Old Jan 17, 2007 | 04:30 PM
DaveSchott's Avatar
Weldon used to have the best FPR on the market, I imagine they are still a top part
Old Jan 17, 2007 | 04:42 PM
onfire's Avatar
Coal Mining Director
I'm using Weldon. Rock solid psi without spikes.
Old Jan 17, 2007 | 04:56 PM
ss1's Avatar
ss1
Which Weldon? I'm assuming the 2040 since they only list two. I like that you added the fact of no spikes.
http://www.weldonracing.com/2040.html
Which Aeromotive are you guys running? I was also looking at the 13109 since I really don't need anything bigger. It's really a matter of preference or opinion at this point. I appreciate all of the replies so far.
Old Jan 17, 2007 | 07:44 PM
EGash's Avatar
I've never had any problems with Aeromotive.
Old Jan 17, 2007 | 08:16 PM
DeltaT's Avatar
I have the big Aeromotive and I have been datalogging fuel pressure with a pressure transducer for ~2 months with only +-4psi variations in pressure under load.
Jim
Old Jan 17, 2007 | 08:23 PM
smokinHawk's Avatar
the speed inc one has worked well for me
Old Jan 17, 2007 | 08:36 PM
Schantin's Avatar
I'm using the aeromotive. Works well so far.
Old Jan 17, 2007 | 10:05 PM
427's Avatar
427
I like the Weldon A-2040 for electric pump.
Kurt
Old Jan 17, 2007 | 10:06 PM
ninetres's Avatar
I have a fuel-lab I got from Nasty Nate.
Old Jan 17, 2007 | 10:21 PM
onfire's Avatar
2040 A FPR is truly tested when you pump a lot of volume through it and the pressure does not spike
Old Jan 17, 2007 | 10:47 PM
1INSANEGTO's Avatar
Magnafuel here
Old Jan 18, 2007 | 04:18 AM
SRZ's Avatar
SRZ
Fuelab here as well.
Old Jan 18, 2007 | 06:15 AM
Senior Member
Ive never had a pressure flux or spike with my Magnafuel. Rock steady under vacuum and boost.
