FI Guage Set up and Prices
I also want to see some unique gauge set ups other than the A-pillar.
I have a 3-gauge pillar with autometer cobalt series fuel pressure and boost gauges in the top 2 holes. I opened up the bottom hole a bit more to fit the 60mm version of a TurboSmart E-boost2.
The cobalt series gauges were around $200 a piece and the E-boost2 was around $450. So, with pillar, my total was probably around $900.
In my case, the boost gauge isn't necessary since the E-boost2 can act as one, but it was left over from when my car had a blower under the hood. Now i just use it to see the pressure difference between before and after the intercoolers while tuning.
As far as cost, I don't remember for the gauges. I have LT1Edit for PCM editing, Autotap with lots of extended parameters for datalogging, and an LM1 for WOT testing. Probably around 1.8k for everything.
$139.00 for boost guage
$159.00 for fuel pressure guage
Hp tuners enhanced EIO version I think around the $600.00 range but don't quote me.
LM! with X gauge
norscogk Fuel psi
greddy profec II boost controler
Digtial RPM gauge with shift light
Thanks
Thanks
i don't have pic of them for some reason lol
the dakota digital is about $150 with the sending unit. (-30 vac to 30psi)
norskog is about $100 with sender ( i want the dakota one but i need other stuff)
WB band is like $400 with LC1 and the X16 gauge
Ebay dual gauge pod - $30.
AEM Wideband - $250
HP Tuners (split with 5 friends of mine) - $155
Wiring the bitch up and running the lines is more of a hassle than anything else.
To add a deeper question to the original topic, what is everyone's top three choices for gauges. My personal must-haves are boost, wideband a/f and fuel.
You could probably make one with some plastic welding skills, but I wasn't about to attempt that. I believe that's what Harlan did to build his pillar.
