Theory Question. Turbo driven turbo...
Now... You FI guru's... tear it apart... I'm sure there is a reason that people aren't doing this... I just want to know why?? I'm new to the turbo scene and lookin' for a good education...
The design is not practical for a gasoline burning engine.
A sequential system has two turbo’s, only one is used at low RPM and the second is brought in as the Rev’s increase to support more power. Both turbos draw air from the atmosphere and push it into the engine. In this type of system boost pressures are not compounded. One example of this is the 4th Gen Toyota Supra, it uses two turbo’s of the same size and brings them on sequentially, one at low RPM and the second as Rev’s increase.
Then there are parallel twin systems, both turbos all the time. This is basically the same as having one turbo, but there are two smaller ones instead of one big one. Most twin turbo systems on gas engines are this way.
As for the first post, I am unclear on how exactly you are talking about plumbing them, can you be more specific?
If you have one turbo feeding another, regardless of the proper technical term, it will obviously make way too much boost for a gasoline burning engine to deal with.
This is a topic that could be researched on the turbo diesel truck boards,
or tractor puller based sites.
sequential turbo is not the same... i.e. not feeding into another...
If you can make 1000rwhp with a single on a gasser, there's no need to add another like this. Sequential or matched twin setups aid in spool time by using smaller turbos which spin up faster due to less impeller mass. Sequential helps more because one is sized smaller to spool really quickly.
The STS design is the reason you can't get better spool time from a rear mount. They lose the efficiency advantage that front mounts have due to loss of exhaust heat over the 10+ feet of piping to get to the rear. Wrapping the exhaust helps somewhat, but that's the only option you have without moving the turbo toward the front.
My setup diverts all the exhaust energy to one turbocharger so you take advantage of the entire displacement to spool the turbo. After certain criteria are met, some of the exhaust stream is diverted to the second turbocharger where it continues operation as a twin turbo system.
The VR-4 was a TT V6 and each side of the V powered a turbo, then using a "Y-pipe", the charge pipe came back together and headed into the TB.
3000GT's have two equal size turbos also. One on each bank. Both are used at all RPM's. They are parallel.
Both parallel and sequential turbos do the same thing, add the flow of two small turbos. The 3000GT uses two really small turbos and makes 320 HP and 315 TQ. The Supra uses two small (but substantially larger than the 3000GT) with a complex control system and makes 320 HP and 315TQ. Stock turbo Supras can make more power than stock turbo 3000GT's.
Compounding and “stage” turbo systems are the same thing. One feeds the other and you get lots of pressure.
Andrew
Not to hijack the thread, but I raced a TT stealth not too long ago. Younger kid...had 2 girls in the car with him so I have to give him applaud for being a
. Raced from about 40mph to 110 or so. I actually wanted to give him a run for his money so I started out 3rd gear verses 2nd. I don't know what mods he had other than exhaust, a huge freaking tach and a shift light.Obviously I'm not exactly in my power band yet and we honk it off. He pulls away pretty quick and I contemplate downshifting into 2nd, but what the hell...I just let it run. Once he shifts into 3rd, I'm about to his back bumper but I'm only doing 70 so I have plenty of gear left. By the time I'm well into my powerband...around 85mph, I'm passing him...then around 100mph, I shift into 4th and just keep pulling him. I let off around 110 or so and had him easily by 2 car lengths.
We're on the highway, but he pulls up next to me and tells me to roll down my car. He begins shouting explicit terms about how "cool" that was to race me. I could barely hear him so I nodded and then took my exit off the highway. Good race though!
