Tc76mps
i am subscribing to this thread cause i am researching to see if this t-76 would be a better street/ wknd track turbo than lets say a S-80 or S-85.
also here are the serial numbers, but they had an X through them. maybe so people at the shiping place wouldnt realize theres an expensive turbo in it????
60SE-SB-H76-D-D-SS
60SE-SB-H76-D-D-SS tundo_46
C/O- 45399
S/N- T-23626
M/O- M280150
60SE - SB - 621 - D - D - SS - TUNDO_96
C/O # 42697
S/N # T-22555
M/O # M258900
my serial number:
60SE-SB-H76-D-D-SS - tundo_96
C/O-45399
S/N-T-23626
M/O- M28150
uuuuummmm i think u cant pass 9psi cause u have the wrong turbo!!!!!!!!!!!!
60SE-SB-H76-D-D-SS
C/O- 45399
S/N- T-23626
M/O- M280150
did u find out what the 76mm flows lb/min wise?
my serial number:
C/O-45399
S/N-T-23626
M/O- M28150
60 series - Standard Bearing - HP76 compressor (T76) - Dry Bearing - Dynamic Seal - S trim T4 turbine (supercedes Q trim) - Tangential Undivided .96 A/R turbine housing
FrcFed's Part number again:
60 series - Standard Bearing - 62-1 compressor wheel - Dry Bearing - Dynamic Seal - S trim T4 turbine - Tangential Undivided .96 A/R turbine housing
You can see the difference and why I gave him that info..
Edit I should say peak efficient flow on the HP76 compressor wheel chart is 90 lb/min
You are the one who actually spoke with him on the phone over @ turbonetics?
