New Product announcement, S-series Turbo
Old 03-20-2007 | 07:38 AM
  #141
1INSANEGTO's Avatar
But I would have room to grow with a S88. Goal is below 9.7
Old 03-20-2007 | 08:35 AM
  #142
DrTurbo's Avatar
LS1TECH Sponsor
Yeah, I believe an S88 would get you 9.7's and then some....lol. I believe the newer S88's are probably good for some 8.2-8.3's in a 3500lb car. Which is AWESOME since they are so small compared to the larger GT series which will run around the same power as well. I thought the smaller covers would effect HP alot, but apparently I was wrong and they do effect them, but not as much as I thought before. They are the most powerful units in a small compact size that I know of.
Old 03-20-2007 | 09:36 AM
  #143
1INSANEGTO's Avatar
Happen to have any pics?
I called and talked to someone yesterday about them. I have seen the GT47-88 turbo and he said it was as big as a GT42.
Anyway I can get a compare pic of the S88 next to the GT47-88 so I can get a idea of size?
Old 03-20-2007 | 09:38 AM
  #144
SSilverSSurfer's Avatar
is there any downfall to running an S80-88 on a near stock cube motor? or is it for the 370+ guys
Old 03-20-2007 | 09:43 AM
  #145
1INSANEGTO's Avatar
I want to run the S88 with a built 346ci
Old 03-20-2007 | 09:46 AM
  #146
your the reason im wondering ive seen a thread about a guy that has a large frame on a 346 and says that the lag isnt half as bad as you would think, you can buy one and let me know how it does then i will swap my q trim 76mm for one if it yields excellence
Old 03-20-2007 | 12:46 PM
  #147
1INSANEGTO's Avatar
with a .96 A/R I do not for see lag as a issue. Now with a 1,01 or higher then hey its a issue,
Old 03-20-2007 | 01:02 PM
  #148
NA$TY-TA's Avatar
The S88 and GT42 are almost exactly the same size.... they bolt up the EXACT same way.....
Old 03-20-2007 | 01:30 PM
  #149
1INSANEGTO's Avatar
I never seen a GT42 I only seen how big a GT47
Old 03-20-2007 | 02:06 PM
  #150
look in jerry's(cablebandit) sig, i think he has a s88 or s80 next to a gallon of milk, and for comparisons sake it looks kinda bigger
Old 03-20-2007 | 02:32 PM
  #151
cablebandit's Avatar
mine is someone elses s400 with an 88 wheel but the external dimensions should be the same as a s85-88
  #152
NA$TY-TA's Avatar
I have quite a few pic's of a GT42 and a S88 ive owned both....
EDIT Just went out and took these with the tape measure...
PIC'S
Old 03-20-2007 | 10:05 PM
  #153
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
The cover being used on your unit is a smaller cover then the new and current S-series units. The 85's+'s use 5" + intake.
Old 03-20-2007 | 10:07 PM
  #154
LS1TECH Sponsor
Nice pics......our new cover is different and is what is used for the OFI kit.
PIC'S
Old 03-20-2007 | 10:10 PM
  #155
LS1TECH Sponsor
No problem at all, we have many folks running them from 2.0L 4 cylinders and 3.0L 2JZ's to 400ci engines. Our S-series can be tailored to fit almost any setup depending on what you want.
Old 03-20-2007 | 10:12 PM
  #156
LS1TECH Sponsor
GT42 vs GT47 cover....
Old 03-21-2007 | 02:22 AM
  #157
my intake is 5"....i am confused a bit about what you mean
Old 03-21-2007 | 07:46 AM
  #158
NA$TY-TA's Avatar
JZ,
Sent ya a PM the other day...... just waiting on your reply.....
I guess ill just have to buy a bigger filter LOL.....
Old 03-21-2007 | 08:10 AM
  #159
DrTurbo's Avatar
LS1TECH Sponsor
I think Jose meant to say 6" inlet, not 5".
Old 03-21-2007 | 09:31 AM
  #160
Firechikn's Avatar
S91 FTMFW!! Next month can't come soon enough.
Quick Reply: New Product announcement, S-series Turbo
