F1-c On Fbody
Old Feb 23, 2007 | 07:24 AM
turimo1's Avatar
Default F1-c On Fbody
I am trying to find out if you can fit an F1-C on an F-body and still keep the a/c. I know u would have move the radiator and condenser forward but has anyone made it fit? pics ? I have read most of the threads and did a search but I cant find a straight answer. thanks
Old Feb 23, 2007 | 08:03 AM
EPP's Avatar
EPP
Apparently Jesse Bubb (wait4me) has. You might try contacting him.
"The 1000 hp camaro can be seen or driven by anyone who wants to come over. I have nothing to hide.
408 with 22~ lbs of boost using an f2R procharger.." Jesse Bubb said this.
https://ls1tech.com/forums/showthrea...&page=33&pp=10
Bob
Old Feb 23, 2007 | 08:24 AM
98turbls1's Avatar
Ac is for suckers... Slap that monster on and route the BOV's relief pressure into the cabin and that'll be cooling enough....Because when that thing releases that will be COOL as hell.... =)
Old Feb 23, 2007 | 08:29 AM
TNTramair's Avatar
I like the way you think . but lets be real, nothing worse than driving the Hotrod Power Tour in 100+degree weather for 6 hours straight...some of us need the A/C....
Bob...theres no significant differance in dimensions between the F1a and F1c are there??
Old Feb 23, 2007 | 08:37 AM
EPP's Avatar
EPP
Question
The volute diameter on the F1C/F1R blowers is larger, also the inlet hose diameter is larger. Bob
Old Feb 23, 2007 | 08:51 AM
Ping King's Avatar
cut the rad support and weld in a piece of 1 inch square tube if you need to move it foward.
Old Feb 23, 2007 | 09:38 AM
TNTramair's Avatar
anyone have pictures of the radiator support cut for the F1????
search doesnt seem to be workin for me.
Old Feb 23, 2007 | 09:40 AM
superchargedbandit's Avatar
YOU ARE RIGHT. I DO THE POWER TOUR EVERY YEAR AND YOU HAVE TO HAVE A/C
Old Feb 23, 2007 | 09:41 AM
turimo1's Avatar
Yes, pics would be nice to see. I would much rather go with an F1-C on my f-body if I can retain the a/c.
Old Feb 23, 2007 | 10:37 AM
Got Me SOM's Avatar
do a search on Stenod built cars, they cut the rad support and weld in the boxed bar like ping king was saying.
I want a 1000 hp blower setup too one day.
Old Feb 23, 2007 | 03:07 PM
Ping King's Avatar
yea a lot of the turbo cars have the rad supports cut. I did mine myself with some 1 inch square tube.
another possibility is to buy a summit or jegs radiator thats 20 or 22 inches in diameter with a thicker core. You could be able to push the radiator over to the passenger side so that youre able to clear the blower inlet. You can still run the condensor for the radiator too.
Old Feb 23, 2007 | 04:51 PM
Dragframe's Avatar
just cut the support out and weld in a new one. I did to make room for my T 76
Old Feb 23, 2007 | 06:27 PM
TNTramair's Avatar
thats exactly what i was thinkin of doin....just getting a custom radiator thats not as long to make the room.
hmmm...decisions decisions....thanx for the pics Dragframe.
Old Feb 24, 2007 | 03:51 PM
Ping King's Avatar
i bought a rad for like 150 bucks from jegs. Just look through the catalogs youll find them.
Old Feb 24, 2007 | 04:33 PM
turimo1's Avatar
Thanks for the info, do u have any pics of an F1-C on your F-body? Which model radiator did u buy? are u still running A/C?
Old Mar 2, 2007 | 10:10 AM
turimo1's Avatar
So no one has installed or seen an F1-C or bigger on and F-body??? how bout and F1-A? anyone have pics??
Old Mar 2, 2007 | 12:22 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
KP has plenty of F1a pics floating around this forum.
Old Mar 2, 2007 | 02:34 PM
ssvert99's Avatar
LS1Tech Premium Sponsor
gimme a few weeks and i'll let you know all about it. i have the F1C sitting here ready to go as soon as the engine comes back from the machine shop... and it will be with the A/C, and fmic.
Old Mar 2, 2007 | 02:38 PM
turimo1's Avatar
SSVERT99, thats good to hear, I will hopefully be in the same boat ur in soon. I expect lots of info and pics. What kind of power are you looking to make? and what CI is your motor?
Old Mar 2, 2007 | 02:41 PM
Cyborg's Avatar
Fitting it along with a/c won't be an issue, fitting it along with your radiator will be though. You'll have to move it way forward. And then getting it to cool with a/c on will be your next issue. You'll need 2 or 3 fans and shrouded airflow into the radiator & condenser.
