What compression should the cylinders be in a low compression FI motor?
Ya, well I was told I can run 91 octane and be perfectly safe on this tune (which I havent touched at all)...
The whole purpose was to have a build that was a somewhat streetable pump gas setup, so im not gonna throw race gas in there unless I need it like during the summer time for securitys sake.
Plus its been in the 40's and 50's F* so heat wouldnt be an issue if detonation is the cause.
. Keep us updated. Good luck on the motor.I think we might try to pull the head after we check compression on the other side to see if its just that one main cylinder thats having issues or if its a general lack of compression for the whole motor.
But hearing the car idle it just idles a little bit rougher then normal, you wouldnt be able to tell theres something wrong until you start getting into part throttle under load.
I just have bad luck with this car, lol. Maybe one day it will be good to me for longer then a week.
I guess it was running about 15 lbs too that day... Its wierd cause the boost is set to run 14 or so, could the excessive humidity with cold air cause the boost to jump a lb or too in boost?
Arizona dyno chip dynoed the car, the guy who ran it "NicD" the local tuner guru here said it looked to be ok but any more is definately not good.
He mentioned something about it reaching burst knock or something?
And for a smaller amount of time it was reaching 110% DC, so maybe lack of fuel could have done it...
I dunno, I guess I'll just have to take it one step at a time and see what happens.
900hp on pump gas and beating on it all the time takes it's toll.The motor wears out extremely fast.We always recommend driving at a low boost level and only turn it up if it calls for it.
More than likely you need to pull the heads off and really see whats going on.I'm guessing the pistons are junk.
edit....trans zam you have more car problems then me and i didnt think that was possible.just try to keep going cause evertime you go WOT it makes it worth it.
Ya, it seems like a never ending battle and just gets so discouraging. It was hard enough to have the initial investment, but having to put more and more money and time into this car each week just isnt as feesable for me as I like.
Its not even a matter of that, I just dont have the time, patience, or know how to diagnose problems as they come, so the car sits for a while till Im able to get it figured out.
At least I still have my health, lol.
believe it or not, Id assume I only put maybe 500-1000 miles of actual hard driving on it, and maybe 100 have been done while it was having those overheating issues.
Other miles were from breaking in the motor, new clutches, and just freeway driving back and forth to work.
.02
It's winter, since you're going to have traction issues, why not turn that boost down? Yeah, you'll make less power, but what's the point if you can't put it anywhere! Sorry to kick a man while he's down, but it's the truth... (or you could've thrown more fuel at the problem, allowing you to keep 15psi)
