900RWHP on pump gas?
Mike
You can not equate boost with wat/meth. Wat/meth alone will not yield you 300hp. It is a tuning devise, aimed at keeping your motor free of detonation.
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
I made 735rwhp on pump gas only in June of last year, with a very conservative tune on a Dynapack. Im sure if I was to push a little harder that could easily see 800 on pump gas only. And thats only with a supercharger on a 382, with a relatively mild spec.
I also ran a lazy 10.52 @ 145mph ( 1.97 60ft ) on pump gas only in October. I only tried one run on pump as the track was very busy. All other runs that weekend were with meth too.
Id hazzard a guess, that my same engine at 8.7:1 CR could easily handle enough boost on pump gas, to make 900rwhp with the right turbo.
But Im quite happy with how my blower is performing, so ive little desire to change.
Ive made over 550 ( flywheel ) HP on 2.0 turbocharged cars on pump gas only. So making twice that amount on an engine 3 times the size, shouldnt be too hard. If you decided you wanted to.
There are no supras, running 900hp with pump gas. The only car I know that can possibly make that, is a viper.
Its mostly used, when race gas is not available or is to expensive to use on a daily basis. Wat/Meth will not stop your motor from grenading. It is a prevention method, not to be used to crank up the boost and add more timing at will.
Yes it prevents detonation, but like engineermike is saying, by cooling and preventing detonation it allows for more boost, and more timing. More boost + more timing = more power.
Race gas these days runs at least $4.50+ a gallon. And it will be consumed with your fuel in the tank, so it won't last very long.
Methanol is usually $3.00 or less a gallon, and out of that one gallon you can usually get an entire night worth of track racing done. Heck, a lot of guys go 50-50 mix on the meth with water, that equats to half the price and twice the use.
Not to mention almost all meth kits are setup to come on at a certain degree of their boost curve. Take that in consideration vs. race gas and there is no way possible that you can argue that race gas is cheeper than the meth.
But then, pump fuel here in the UK is circa double what you are estimating for race gas. So I'd say any type of fuel you guys use is cheap. Race fuel here could be anything from $20-30 upwards per gallon depending on spec. Probably a lot higher than that for decent stuff.
So basically our pump fuel is about double what you guys pay for race fuel....and it gets used all the time. Hence why I only use pump fuel !!! its too damn expensive to use anything else ( except added meth )
Methanol is still relatively cheap though ( it isnt taxed heavily here ), but as a sole fuel, it would still add up.
Injecting methanol is probably the cheapest "boost" you can give to your fuel system.
I still dont belieive, that if AFR's are tuned safe, and the engine is detonation free, why pump fuel should pose any danger to an engine.
If I get enough track time this year, I will make quite a few passes on pump gas only, and then with meth.
As long as IAT's are in check, and AFR's and timing what I would see as safe, I will have no hesitation in trying.
its exactly how I run it on the road all the time anyway, and it gets its fair share of abuse there too.
Ive run over 30psi on Subaru engines at 8.2:1 on pump fuel only. Ive only ever once lost a head gasket through detonation. Never a piston. I knew it wsa detonating at the time when we were tuning....so it was to be expceted. Totally my fault.
if its detonating, you are trying to use too much boost or CR, for the fuel..
NOT that its the incorrect fuel or there is a fuel problem.
and he build it for street use only.
BUT I THINK HE JUST BLOW HIS ENGINE
just because you can get through 4th gear on the highway or dyno at 7,8,9,1k and pump gas does not mean everything will be fine at the track.
