900RWHP on pump gas?
There are no supras, running 900hp with pump gas. The only car I know that can possibly make that, is a viper.
he is a memeber here under the name parish8. and the video title says 6.0 but its a 408
**** anything above 800 rwhp is wicked fast on the street.
as long as you can keep the heads down, you can make the power.
methanol lowers the intake air temps down to almost to ambient or less which prevents detonation.
i believe he said the car went 125 in the 1/8 which is flyin
And the stock head thing dont surprise me.... i bet i could make 500 with low compression pistons on the stock lt1 heads...
Having good heads helps a lot tho...
after seeing some serious fast turbo cars run at the track yest, i have turbo envy but unfortunately for me I dont have the funds to convert over.
Mike
Grenading is caused by bad tuning and detonation (weaker parts when power gets to the pretty crazy levels), water/meth can most definitely help stop detonation and thus stop the grenading.
Alky is great cause its kind of like nitrous. Its not always running, so you are efficiently using it only when its needed. Race gas on the other hand is being burnt the whole time.
I use alky to turn up the boost and timing at will and think with the new L92s and LS7s, use over 400ci, 1000rwhp on 93 octane is very obtainable!!
