how much $?
Old Feb 26, 2007 | 09:01 PM
  #41
MetallicaMatt's Avatar
yeah it'll cost a small chunk lol
i got quotes for fuel upgrades
I think i might run a single large turbo, like a 76GTS
Old Feb 26, 2007 | 09:19 PM
  #42
SSilverSSurfer's Avatar
s80 or s76 ftw
and you cant go wrong with the fuel systems that nasty peformance puts together, they come with everything you need
Old Feb 26, 2007 | 09:30 PM
  #43
yeah the nasty quote was sweet. lot of $ but seems well worth it.
Old Feb 26, 2007 | 09:47 PM
  #44
in this hobby, i figured out you get what you pay for, so im gonna stick by that, good luck with the build and keep us updated
Old Feb 26, 2007 | 09:55 PM
  #45
yeah I wanna do things right.
someone on here helped me with what parts I would need if I want to use my stock block
and another member has a built motor, never installed for sale....
hard to decide!
Old Feb 26, 2007 | 09:59 PM
  #46
whats the specs on the built motor? cubes? compression?
Old Feb 26, 2007 | 10:03 PM
  #47
-LME built 370
-Lunati crank
-Lunati 6.125" Pro Mod Rods
-Wiseco 25cc dish pistons
-Hell Fire Rings
-Clevite rod,main, and cam bearings
-Custom 23x/23x turbo grind Cam Motion cam
-Crane Hyd. Roller Lifters
-Roll Master double roller w/ torrington bearing and nitrided gears
-Felpro head gaskets
-TEA Stage 3 AFR 205 heads
-flow 343 cfm @ .600 lift
-same port job as heads on W2W record holding LS1 TT motor
-Jesel SS Shaft Mounted Rockers
-Comp Cams 921 springs
-105mm Accufab throttle body
-105mm Wilson Manifolds Elbow
but i would still need an intake and other misc things
Old Feb 26, 2007 | 10:33 PM
  #48
nice find, id jump on that and do an s80
Old Feb 26, 2007 | 10:36 PM
  #49
how much ya think its worth?
Old Feb 27, 2007 | 12:29 PM
  #50
so based on post #47
should I go with that block, or save some money, build up my stock block and go from there?
bump for the day i guess lol
Old Feb 27, 2007 | 01:19 PM
  #51
CALL911's Avatar
I say go with the items in #47. 9 times out of 10, you'll always wish you had spent the extra $ for the higher quality parts, even if it means you need to wait just a little longer to save up the extra $.
Old Feb 27, 2007 | 01:31 PM
  #52
cool thanks man
whats everybody else think?
Old Feb 27, 2007 | 01:37 PM
  #53
MIGHTYMOUSE's Avatar
i say you can do it for less
stay stock crank
gm mls gaskets
stock replacement head studs
go with a solid cyl head that is not hogged out so much to keep strength, let the boost make the horsepower
you don't need the fancy intake to make 7-800 so that would have to be cosmetic for you
keep stock rockers
there, i saved you at least 3 grand so a check back to me for 1k is fine
Old Feb 27, 2007 | 01:40 PM
  #54
PM'ed ya Mouse
Old Feb 27, 2007 | 02:05 PM
  #55
damn i posted after MM so i wont be getting that check, lol,
basically what he said, the stock block and crank will be good for you,
good luck
Old Feb 27, 2007 | 02:25 PM
  #56
ddnspider's Avatar
i think if u can get a good deal on that LME setup do that because remember you if you get everything new or already together you can sell the entire motor in your car to make back a couple $1000,thats what i did and was definitely worth it.
Old Feb 27, 2007 | 04:16 PM
  #57
Dragframe's Avatar
6k into turbo... motor would have to be about 6k.... some money into tranny and rear end.... 1k into fuel system AT LEAST
i could make 500 rwhp for 8.5k.... starting with a stock car...finishing with stock pcm...stock fuel regulater... stock heads (unported with good springs and hardware) stock intake... and stock crank =)... paying full retail for everything
Old Feb 27, 2007 | 04:20 PM
  #58
would a GMPP intake be good enough for that LME block? It has an accufab 105mm TB
Colbalt maf? stock pcm?
what size injectors am i looking at? I'll be buying my fuel upgrades from Nasty Performance
Old Feb 27, 2007 | 04:26 PM
  #59
if you have a LS6 intake your saving yourself money right there, plenty of guys have taken it to 1000hp, so its not a restriction, the GMPP intake would help with distribution but its not a necessity
Old Feb 27, 2007 | 04:45 PM
  #60
cool, i have an '02 so that should be the LS6 intake if i'm not mistaken...
