Boosted 6 speed 60ft's
Old Mar 3, 2007 | 03:12 PM
navymitch12's Avatar
my best 60ft so far is 2.2 with toyo t1r's and clutchmasters clutch
i was playing around with a lot of different launch rpm's that night so i really dont know where exactly i was for that one.
Old Mar 3, 2007 | 05:37 PM
99Z28LS1's Avatar
i wanna give it another try when i get a twin disc..... should be a lot better with wrapped exhaust and a good cam that doesnt bleed much boost
Old Mar 3, 2007 | 07:10 PM
Cyborg's Avatar
I was expecting to see much better times in this thread. I thought I was the only one w/ horrible 60' times LOL. I still attribute my 2.0 & 2.1 60's to lack of seat time though. 2 or 3 times I've cut 1.7s, but usually I'm 2.0-2.1 on 255/50/16 MT DR's w/ ~12psi, Spec 5, eibach springs, Bilsteins, stk TQ arm, Spohn LCA's & relos, no 2 step. I would like to use a 2 step for consistency, still slip the clutch, and switch to 315/35/17 MT DR's if & when they come out, or BFG DR's same size if they don't, and then get a bunch of practice.
Old Mar 3, 2007 | 07:59 PM
otherwhitemeat's Avatar
i agree.....1.8-2.2 60 foots can be achived on street tire...while just walking out of the hole
Old Mar 3, 2007 | 08:03 PM
stevieturbo's Avatar
2.0+ is easy on pretty much any decent tyre IMO...
Going sub 2.0 is much harder ( I wouldnt class a MTDR etc as a street tyre BTW )
But then street tyre means very different things here in the UK. I class the MTDR's as race tyres.
I know I was never able to go sub 2.0 on a regular street tyre.
What sort of 60fts are you achieving then otherwhitemeat, and using what tyres ?
Old Mar 3, 2007 | 08:06 PM
Stevieturbo..........when i said street tire i meant factory tires like goodyear eagle gt's
Old Mar 3, 2007 | 08:08 PM
with mtdr i was getting 1.6's........with real street tires 1.8-2.2's. this was long ago when the car was alot slower.
Ive seen a new Merc SL500 or something like that go sub 2.0 on road tyres, but that was an automatic.
Going sub 2.0 with normal tyres is pretty hard on a manual car !! Ive never seen a big heavy car do it.
Old Mar 3, 2007 | 08:09 PM
Any details of the car ? I assume it was manual ?
Old Mar 3, 2007 | 08:15 PM
Well, seven years ago, it had heads, cam, and related bolt-ons. Yes, it is a 6-speed and I was able to get it movin' pretty decent off of the line. I also disconnected the front sway bar as well to help keep some load on the tires.
Old Mar 3, 2007 | 08:44 PM
SKI's Avatar
SKI
Cool
1.8 on steet tires,1.6 on nittos .That is on a 16 inch rim with stock clutch .
Old Mar 3, 2007 | 08:46 PM
  #32
you guys running street tires....what air pressure are you running at the track? do you air them down?
Old Mar 3, 2007 | 09:50 PM
  #33
ddnspider's Avatar
i was interested mainly in street tires/drag radials in larger diameters(17/18) to see what others are doing.i had a friend show me how to leave in boost using all 3 pedals at the same time but its horrible for a clutch.lol.
stevieturbo how do you launch?
Old Mar 3, 2007 | 09:53 PM
  #34
02SSLE's Avatar
I turn 1.87 60's with MT drags leaving on no boost. Still trying to figure it out.
Old Mar 4, 2007 | 07:33 AM
  #35
As I said....hardest Ive launced is circa 4500rpm, modulating the throttle, and letting the clutch out fairly slow ( perhaps over 1-1.5secs )
Most runs have been at lower rpm's though..
Mostly this has been for fear of smoking the tyres, but as I said, Im still exploring the grip of the DR's But when I get such little track time, I have to play safe and launch what I know will be consistent. ( plus concerns about the stock 27T output shaft )
Old Mar 4, 2007 | 12:27 PM
  #36
chasgiv3's Avatar
Best I could muster on a 6-speed with BFG dragfs radials was 1.79
Also a firend of INTMD8's and I was running a clutch on a launch and the thing exploded and cut through one of the pedals with schrapnell. If you're going to launch at high RPM's I would definitely consider a REAL scatter shield. Losing a foot could put a quick stop to your 6-speed fun.
Old Mar 4, 2007 | 12:30 PM
  #37
What make of clutch where you using, and what sort of rpm's ?
Old Mar 4, 2007 | 01:41 PM
  #38
ddnspider's Avatar
ditto what clutch and what rpm...also anyone know where to get a bell housing sheild for a t56?ive got the tranny blanket but that wont stop anything if the clutch explodes.
Old Mar 4, 2007 | 01:52 PM
  #39
Cant you get Kevlar blankets for the bellhousing ?
There was a post ages ago on LS1Tech showing fitment of a full SFI bellhousing. Seems like a lot of work, although the guy did have to do some trimming to make it fit....which may have affected its legality.
Old Mar 4, 2007 | 02:32 PM
  #40
speed inc sells both a sfi bell housing and a sfi blanket
