Boosted 6 speed 60ft's
Old Mar 4, 2007 | 07:00 PM
  #41
Cyborg's Avatar
McLeod makes a SFI approved bellhousing, is a slightly custom install.
Old Mar 4, 2007 | 07:35 PM
  #42
ddnspider's Avatar
ive got the RCI tranny blanket that speed inc sells but its not for the bellhousing.where could u get a kevlar blanket for the bellhousing.
Old Mar 4, 2007 | 08:04 PM
  #43
v8juice's Avatar
I actually managed to pull a 1.9 on ET street radials while dropping the clutch under 1800 rpm.
Old Mar 5, 2007 | 01:24 AM
  #44
99Z28LS1's Avatar
did the same but at about 2k
Old Mar 5, 2007 | 01:29 AM
  #45
nvmy2000ss's Avatar
My best to date is a 1.8 on BFG's, 16lbs of tire pressure. I think I can cut some better ones if I get the tires hotter though.
Old Mar 5, 2007 | 11:21 AM
  #46
Zombie's Avatar
My best 60' as a 6spd car was 1.95 on ET streets. After changing to a TH400 my best 60' is a 1.57... neener neener neener.
Old Mar 5, 2007 | 11:27 AM
  #47
99Z28LS1's Avatar
awesome, are we in the 5th grade..... i love it ha ha
Old Mar 5, 2007 | 11:56 AM
  #48
kcmags's Avatar
My best 1.46 with ET Street's... QA1's ...No front sway bar...Spec III
Old Mar 5, 2007 | 01:15 PM
  #49
ggk's Avatar
ggk
WOW Zombie get owned lol jk
Old Mar 5, 2007 | 03:27 PM
  #50
Zombie's Avatar
I have BMR boxed LCA's, an airbag in the right rear spring. The rest of the suspension is factory stock (including the tq arm) with 80k miles on it. Did I mention the 2.75 rear gear that I run too. I don't run skinnies either, stock 17x9 SS wheels.
I'm hoping with some susp work and switching to a 26x10.5x15 tire (using 26x11.5x16 now) I can get in the 1.4x range. What I have now doesn't seem to work too bad though.
P.S. I can't launch a 6spd car to save my life, I flat out suck at it. It was easier to mod the car than my driving (3 years of launching 6spd cars and I was still mr. 2.0 60' lol )
Old Mar 5, 2007 | 05:16 PM
  #51
chasgiv3's Avatar
What make of clutch where you using, and what sort of rpm's ?
I was using the McLeod Twin Disk. RPM's were about 4000 and I slipped but almost dumped the clutch. The track was dead hooking with VHT. The BFG's really hooked well with low tire pressure. I wish I could remember the pressure but I was playing with them all day. The McLeod twin never gave up the ghost. I'm looking at the slip and with the 117MPH I think I may have been spraying the car with a 125 dry shot. I had a 12 bolt in there at the time.
Old Mar 5, 2007 | 08:07 PM
  #52
SSmokin 01's Avatar
Best 60' on a 325/50 MT DR was a 1.67 with 14psi pre-burnout coming out at 4800. Anything above that wasn't happening.
First and only time out on the 28x13.5 Hoosier QTP's so far was 1.70 with a bog. 13psi cold coming out at 5400. Working through a rich condition after the initial hit. Had a much better run later on (added timing) but missed a shift and screwed the run. I was so angry I never picked up my slip . Broke a u-joint shortly after. I've been kicking myself everday until I get back to the track.
ditto what clutch and what rpm...also anyone know where to get a bell housing sheild for a t56?ive got the tranny blanket but that wont stop anything if the clutch explodes.
http://thunderracing.com/catalog/?ac...&vid=3&pcid=18
Install threads:
https://ls1tech.com/forums/manual-transmission/258875-mcleod-sfi-bellhousing-installed-pics-info-within.html
http://fastls1.com/forums/showthread.php?t=10218
__________________
Old Mar 5, 2007 | 08:42 PM
  #53
ggk's Avatar
ggk
Zombie i was just kidding. You are doing better than me, i cant even drive. lol
still 15 and i dont even own a boosted 6 speed let alone even a 6 speed car. so props to yah all!
Old Mar 6, 2007 | 07:55 PM
  #54
ddnspider's Avatar
ssmoking01...damn thats a tire(325/50)
ttt....anyone know where to get a kevlar blanket for the bell housing id rather not take off the tranny to get 1 of those bell housings plus a blankets gotta be cheaper than $450
Old Mar 6, 2007 | 09:50 PM
  #55
WS6 #3392's Avatar
1.59 with 27x11.5 Hoosier QTP dropping clutch. The rest is in my sig.
Old Mar 6, 2007 | 10:41 PM
  #56
ddnspider's Avatar
now heres my next question....how much did tubular LCA's/panhard bar/Torque Arm help your guys 60'?
Old Mar 7, 2007 | 06:31 AM
  #57
WS6 #3392's Avatar
I don't have any before and after info on that sorry.
