Boosted 6 speed 60ft's
Old Mar 2, 2007 | 04:09 PM
ddnspider's Avatar
Default Boosted 6 speed 60ft's
just wanted to see what other M6 guys are doing for their 60' times.Please state if youre using a 2 step,what clutch,and what size tires and suspension.
Old Mar 2, 2007 | 07:22 PM
qqwqeqwrqwqtq's Avatar
Back when my car had 27x11.5 15 Hoosier QTP's, QA1 shocks, spohn torque arm and mcleod twin disc it pulled 1.49-1.51 60ft's off of a 4,400 2-step.
Now with 275-40-17 MT et street radials, stock suspension (bilstein level 2), spohn torque arm and mcleod twin disc it pulls 1.54-1.60 60ft's slipping the clutch out at 5k+.
Old Mar 2, 2007 | 07:42 PM
02SSLE's Avatar
I am interested in this also.
Old Mar 2, 2007 | 08:04 PM
THE_SUPRA's Avatar
i three llololololzzzzzzzzzzzzzzz
Old Mar 2, 2007 | 08:11 PM
MIGHTYMOUSE's Avatar
most of the time i was cutting high 1.7's on street tires and high 1.6's on qtp's, but didt manage a couple 1.5's taking it up to the shiftlight and doing a quick slip
with the two step it would cut 1.7's or break something..
Old Mar 2, 2007 | 08:26 PM
ddnspider's Avatar
Intim8 those times ur cutting now on the et streets is that on a 2 step?
MM were u cutting those 1.7's off the 2 step?what size and kind of street tires?
Old Mar 2, 2007 | 08:30 PM
The 1.54-1.60 60ft's on the ET street radials is with no 2-step, just slipping out the clutch at 5k+rpms.
Old Mar 2, 2007 | 08:35 PM
ddnspider's Avatar
do you have any tips for us without a 2 step specially with those with minimal suspension or a stock rearend on how to launch?
ttt for others too
Old Mar 2, 2007 | 09:02 PM
Well, it's a real balancing act between the clutch and the gas. You want enough rpm's to be able to come out under power. You also want to be holding those rpm's on the line with the clutch pedal up high enough to where it's nearly making the car creep forward.
From that point, when I launch, I simultaneously feed in the gas and clutch. The key is to do it very quickly, but very smoothly. When it's right it feels like you launched the car with a nice torque converter and not a clutch. Whack the accelerator to the floor or let the clutch pop up and you've either bogged it or the tires are history. I pivot my feet on my heels for both the clutch and gas when slipping it out.
Tires are also very important. The MT street radials really impress me. I use the same technique when I'm running my car on the Goodyear GSD3's but it's still a second slower because their is so much less traction (10.8 on the GSD3's and 9.8 on the MT's).
Also, I would never do it with a single disc clutch and if you're launching this aggressively with a stock rearend, have a tow truck on standby.
Old Mar 2, 2007 | 09:16 PM
otherwhitemeat's Avatar
i was gettin low 1.6's back when my car only went 12's,......with et streets.
Old Mar 2, 2007 | 09:17 PM
ddnspider's Avatar
lmao....ill be launching with a spec 5 and a 285/35/18 nitto 555R ill basically be happy if i could get a sub 2.0 60'
Old Mar 2, 2007 | 10:14 PM
fletchls1's Avatar
[QUOTE=INTMD8]
Tires are also very important. The MT street radials really impress me. QUOTE]
How many pounds of air do you run in your MT streets?
Old Mar 2, 2007 | 10:51 PM
Originally Posted by INTMD8
Well, it's a real balancing act between the clutch and the gas. You want enough rpm's to be able to come out under power. You also want to be holding those rpm's on the line with the clutch pedal up high enough to where it's nearly making the car creep forward..
i agree this will work....but only a hand full of passes.......if you want your clutch to last.......put a 2-step in the car.......a 2-step is no big deal to install and is way better of the car, not to mention it makes the car way more consistent and you can actually leave with boost, so your 60 foot's will be way better.
Old Mar 2, 2007 | 11:04 PM
Depends on the tire. My car went nowhere trying to launch it with the 2-step on radials.
fletchls1- 20-22psi in the tires
Old Mar 2, 2007 | 11:30 PM
ya...... some drag radials suck at the track, but are great on the street. with the 2-step we all need real drag tires
Old Mar 3, 2007 | 12:33 AM
SuperZ's Avatar
Ive ran mine on some Nitto DRs with no 2step and never got a sub 2.0 sixty.I think I coulda if I ran it more than a few times.But I cheated and went TH400
Old Mar 3, 2007 | 08:43 AM
ddnspider's Avatar
the only negative thing about a 2 step is it shortens the life of the turbo(s) and if you have a nice turbo thats alot more than the price of a new clutch,but i dunno how much shorter the life for the turbo really is.
Old Mar 3, 2007 | 12:07 PM
Schantin's Avatar
My 60' times. They suck 2.40 on MT Drag Radials (16") set to 18PSI with a 3000RPM launch feathering the clutch. Clutch is a Textralia and it likes to just grab, which add in boost = tire smoke. Actually do better on 18" Kumho ECTA's. 60' times for those are around 2.1. The rear suspension is all UMI stuff and it is set right. Car just won't stay on the pavement in 1st gear
Old Mar 3, 2007 | 12:12 PM
ddnspider's Avatar
and nobody currently makes a 2 step besides synergy?i wish i could find a schemaic on the circuit for a 2 step cause i have access to making chips and circuits and such.has anyone heard about the new EFI Live having a function to add a 2 step using the stock computer?
Old Mar 3, 2007 | 02:58 PM
stevieturbo's Avatar
Ive done 1.8x on 245/50x15 Nittos, and a few 1.7x on 255/50x16 DR's
I wouldnt say they were particularly hard launches though. Im still exploring the grip available with the MT DR's, so I fully hope to see those times drop a fair bit this year with a hard launch.
Might be late april or so before I get to a proper drag strip though.
Most Ive tried is about 4500rpm, modulating the throttle, and with a little bit of clutch slip. Tex OZ700.
Best run was 1.73 60ft.....missed 4th gear tho. Best ET was with a 1.758 60ft. MTDR's at about 15psi hot.
Seeing as its gripped everytime, I know I can try a lot harder than that.
