new sts kit ???
Old Mar 8, 2007 | 06:51 PM
vipvegas's Avatar
Default new sts kit ???
after installing my kit on an 01 ws6 is it safe to drive stock, we are talking right out of the box installed
Old Mar 8, 2007 | 06:56 PM
crazycat's Avatar
you can drive it, but take it real easy untill you get a tune..
Old Mar 8, 2007 | 06:59 PM
SuperZ's Avatar
you can run 5ish PSI on a everything stock car but you should prolly have it tuned first for the fuel and timing
Old Mar 8, 2007 | 07:13 PM
Zombie's Avatar
negative ghostrider.
Do not boost at all, not even one short pull. Get it tuned. It's ok to drive the car like grandma, but don't go beyond that.
Old Mar 8, 2007 | 07:26 PM
Frost's Avatar
+1
The stock timing is waaaaaaay high with factory compression and without tuning for fuel you are just looking for a broken piston. It HAS to say that in the STS literature somewhere.
Old Mar 8, 2007 | 08:24 PM
vipvegas's Avatar
didnt know if I had to tow the car to get it tuned. I have new injectors and a fmic too.
Old Mar 8, 2007 | 09:38 PM
trtturbo's Avatar
If you have bigger injectors installed, you need to have it towed. That much extra fuel can wash the cylinders out.
Old Mar 8, 2007 | 09:44 PM
MikeD101898's Avatar
It is definitely not worth the risk after you put that much work into it. Just tow it to be safe.
Old Mar 8, 2007 | 10:30 PM
Mi11z's Avatar
+++++++++++++1
Old Mar 8, 2007 | 11:15 PM
RooRnZ28's Avatar
tow it, it will save you a headache. believe me!!
Old Mar 8, 2007 | 11:48 PM
99Z28LS1's Avatar
+1 on the tow, i had all my **** done at once, that way i could beat on it after she was tuned
Old Mar 8, 2007 | 11:52 PM
67Firebird455's Avatar
I didn't even think of driving mine until I had a tune to back the damn stock timing out of it first of all and to richen it up a bit. I really dont think it's worth cruising around trying not to boost, it's just too damn hard when you hear that thing spooling up to not hammer down... just my .02.
Old Mar 9, 2007 | 01:16 AM
Ferocity02's Avatar
No need to tow it. Drive it to the tune shop with stock tuning and injectors. DON'T get into boost though, or bye bye motor. Then take 15 minutes at the shop to install the injectors. This will save you hundreds on the cost of towing.
Old Mar 9, 2007 | 07:38 AM
trans2000am's Avatar
question then for you guys now getting ready to put everything back together on my sts build now i got different heads and all and new springs i have to drive on them to let them heat up and cool down before i go straight to the dyno,or risk the chance of breaking the valvesprings, now i also go bigger injectors 42"s now can i install them and drive on them to get my valvesprings worn in, or will i wash out my cylinders not having the tuning on the bigger injectors? to much gas going into them
Old Mar 9, 2007 | 02:08 PM
Nads06111's Avatar
if you are going to tow your car, your better off joining AAA and getting the (plus or gold i forget what its called) membership because you get like 3 free tows.
Old Mar 9, 2007 | 06:35 PM
Frost's Avatar
It was just posted above.... just swap the injectors out at the tuner's shop, they take like 15-20minutes.
Old Mar 9, 2007 | 08:45 PM
2002ws-6's Avatar
I agree with frost, I changed my injectors in the parking lot and I put my 2bar Map sensor in also. I was just real careful not to go crazy on the highway, Then I realized that driving in L.A. during rush hour, the only thing going crazy was me Sometimes I hate living here, mainly when I want to get on the highway and but then stop cause all the cars. oh well time for a
