Trying to make 600rwhp..
Old Mar 9, 2007 | 06:57 PM
trey04gto's Avatar
Default Trying to make 600rwhp..
Iron 6.0L .030 over (370) 8.6:1 static compression
D1SC @ 12-14psi
TEA stg 2.5 heads
224/232 .581/.595 114 LSA
Kooks LT's, catted midpipes borla catback
Aeromotive fuel system
all through a T56
Oh this is in a GTO
I am asking because to run the times I am shooting for I am pretty sure I need 600+
Thanks for helping me figure this out!!
Old Mar 9, 2007 | 07:42 PM
trey04gto's Avatar
Procharger guys??? 370 guys???
Old Mar 9, 2007 | 07:53 PM
ChrisUlrich's Avatar
if I had to guess... i'd say yes. If not 600whp... then 599whp
Old Mar 9, 2007 | 08:01 PM
trey04gto's Avatar
I am trying to get my setup complete before we do final tuning. If I cant get there with this I have about another 5,000 rpm on the blower, meth, or a small shot. I would like to get there with this though. To get that last 5,000rpm I would have to change the crank pulley and that is $450.00.
Old Mar 9, 2007 | 08:03 PM
That much boost with that setup should get you real close to that type of power. People are making 700+whp on a D1... pretty sure anyway. No reason why 12-14psi wouldn't make 600. Especially on that nice cam and heads.
Old Mar 9, 2007 | 08:37 PM
Slowhawk's Avatar
LS1Tech Sponsor
D1SC @ 12-14psi
TEA stg 2.5 heads
all through a T56
Oh this is in a GTO
I'm guessing this is a setup you plan to go with and your asking us if it will make 600hp?
Yes.But I would raise the compression to 9.5-1 and dump the aeromotive pump(too loud)
Old Mar 9, 2007 | 08:42 PM
trey04gto's Avatar
Yes it is... and yes the aeromotive is ridiculously loud. however, at wot there is absolutely no pressure drop. Think it will get me there? My motor has already been completed. I am in breakin right now. I wanted to stay a little on the safe side...
Old Mar 10, 2007 | 12:36 AM
trey04gto's Avatar
Any late nighters?
Old Mar 10, 2007 | 12:47 AM
ninetres's Avatar
Jesus, I hope you would make 600!
I made 653 on my stock 347 with only 10 psi through a T76gts. Had out-of-the-box patriot heads and a mid size cam.
Old Mar 10, 2007 | 01:25 AM
trey04gto's Avatar
LOL...Damn I hope so too!! The only part of my build that I think may keep me away from 600 is my compression.
Old Mar 10, 2007 | 05:41 AM
EPP's Avatar
EPP
Smile
D1SC @ 12-14psi
TEA stg 2.5 heads
all through a T56
Oh this is in a GTO
At 14 psi I'm going to bet you will be at 650+ rwhp, even with your lower compression ratio. Take a look at the builds we do that make over 700+ rwhp.
The closest one we have to your set-up is making 757 rwhp with 16 psi of boost.
http://www.exoticperformanceplus.com...Car.php?car=42 Bob
Old Mar 11, 2007 | 10:07 PM
trey04gto's Avatar
Any other takers? hey real quick...What would help the most another 3-4psi of boost(maxing D1SC rpm) or methanol/ethanol injection?
Old Mar 12, 2007 | 05:09 AM
EPP's Avatar
EPP
Another 3 to 4 psi of boost would make the most. Now if you combined the added boost with methanol, and added back in some of the timing that was removed, you'd really add a boatload of power! Bob
