Ninetres's new forged 364 build thread
Very cool. I have a TH400 and 3,25 gear in my 9 inch as well in my 2000 Z28 turbo car. Its nice to know i can run my 315 BFG DR's on my 17x11 ZR1's and still cruise down the interstate at 3000rpm.
Originally Posted by FANTAZ28
with a th400, and a 3.25 gear
70mph at 3000 rpm with a 26inch tall tire
70mph at 2700 rpm with a 28 inch tall tire
First off car is looking awsome man.....
Those RPM's @ Cruise will be awsome.....
It isnt to bad driving on the freeway...... i do it all the time with a 3.54 rear gear.....a lil higher then Tondss. (28" tire)
60mph @ 2700rpm's.
Now comparing that to a 4L60E car.....
My car before....
in O/D with a stock size tire..(26")
3.73's out back i was 2500rpm's @ 70mph
60mph @ 2700rpm's.
My car before....
60mph @ 2700rpm's.
My car before....
![Leghump](https://ls1tech.com/forums/images/smilies/LS1Tech/leghump.gif)
My only RPM issue will be that on the street I will be on some 315 17" ZR1 wheels. What are those.....25--26 inches?
Originally Posted by ninetres
Thanks man. Means a lot coming from you....I <3 your car
25.7"s is stock diameter.....
It depends on who's tire for the 315.... its a lil taller....
Kyle
#34
Originally Posted by 2002/Black/SS
ok but on the ride home ill pass u going 85@1500rpm
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Seriously though. I USED to be a DIE HARD 6 speed proponent. You will get tired of clutch issues, and losing to cars that beat you because your car is wasting time between gears, and falling slightly out of full boost.
#36
Huh? Only if I let you. And my *** will probably be hurting from sitting on the wad of money I took from you and your six speed cruiser
You should put your car back to stock....it drives sooooo smooth and comfortable in stock form!
also any car that can beat my turbo SS because i cant shift fast enough deserves to beat me!!
#37
More pics up!!!! Motor is in and custom solid mounts to make more room for big d*ck downpipe made ![Headbang](https://ls1tech.com/forums/images/smilies2/headbang.gif)
http://calibercustoms.com/cagle_camaro_2.htm
![](http://calibercustoms.com/images/100_1424.jpg)
#38
Motor mounts look nice. I have thought of doing the same thing for my car. I still have a little time before I go bigger though. I am gonna max the TC76MPS that is on the car right now.
#39
Get off my 4" thick.....pipe!
The 4" DP makes my T76gts look baby
![](http://calibercustoms.com/images/100_1440.jpg)
Only a couple days of work left, then all the piping goes to the powder coater for some high temp black, and my driveshaft gets ordered!
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
