Head selection
Old Mar 27, 2007 | 05:42 PM
john_sblendorio's Avatar
Default Head selection
I decided to scale back on the cubes a little and go FI on my build. What heads would you recommend for a 427ci / Vortech Ysi build?
Old Mar 27, 2007 | 08:35 PM
2001WS6Vert's Avatar
What cubes were you before if a 427 is downsizing?
Old Mar 27, 2007 | 08:37 PM
ninetres's Avatar
225 AFRs with a 72cc chamber.
Old Mar 27, 2007 | 11:56 PM
SSilverSSurfer's Avatar
Trickflow 225's ftmfw.
check out TEA they have them on their website
Old Mar 28, 2007 | 11:04 AM
471c1 that Steve at RED was going to build.
I am suprised to hear 225cc heads. I would have thought they were too small. What about an ls7 based design, ETP, LS7, L92, etc.?
Old Mar 28, 2007 | 11:15 AM
LASTLS1 is running the ETP LS7's on his TT 408 and his set up is stout, GM LS7s wouldnt be bad either those things flow like crazy wtihout even porting them
Old Mar 28, 2007 | 11:47 AM
That is what I was thinking. How about the Livernois CNC ported L92's> They flow great as well and are very reasonably priced. I need to get fuel rails and injectors anyway, so swapping to a L92/l76 would save money and outflow an Ls2 setup.
Old Mar 28, 2007 | 11:51 AM
NA$TY-TA's Avatar
ETP makes some awsome heads...... give them a call....
Old Mar 28, 2007 | 12:47 PM
to be honest ive been quite dissappointed at the latest L92 numbers, it seems all the hype built them up too much and they werent producing numbers i was expecting. that just my opinion
Old Mar 28, 2007 | 02:45 PM
Chad@LivernoisMotors's Avatar
LS1TECH Sponsor
You really can't go wrong with our L92's. The flow numbers speak for themselves in terms of bang for the buck. PM member " ZLEEPER " on here. He is currently assembling his build with a pair of Livernois L92's.
Chad @ Livernois Motorsports
Old Mar 28, 2007 | 06:21 PM
ddnspider's Avatar
which ever u choose make sure it has a thick deck(ie 5/8's etc)
Old Mar 28, 2007 | 06:23 PM
52172's Avatar
definetly ETP ls7 heads if you got the cash might as well go titanium valves too so you can rev the **** out of it.
Old Mar 28, 2007 | 06:27 PM
52172's Avatar
Maybe because they are already ported, but you probibly know that already. They are not hand ported however.
Old Mar 28, 2007 | 06:30 PM
52172's Avatar
That is the route I would go if on a budget, but if not go ETP ls7 heads.
Old Mar 28, 2007 | 06:54 PM
That is what I was thinking. I am going to need the extra r's since I have 4.11 gears.
Old Mar 28, 2007 | 07:24 PM
52172's Avatar
Sounds like a plan go titanium intake and sodium filled exhaust valves for the rev's and livernoise l92 if on budget otherwise etp ls7.
Old Mar 28, 2007 | 08:23 PM
Yes - that is the plan. The ETP's are really nice, but really expensive. I am waiting to see flow numbers from Livernois. I am more concerned with exhaust side flow than intake. The stock L92's are a little light from what I remember.
Old Mar 28, 2007 | 08:38 PM
52172's Avatar
Great plan and good luck in every step of the upgrade!
Old Apr 25, 2007 | 11:31 AM
It looks like the CNC L92 heads flow better on the intake and eaxhust side than the ETP 4.0 LS7's and better than the 4.1 LS7's exhaust but not as good on the intake. Considering I am planning FI, should it matter that the intake side is not as good and that the L76 intake is not as good as the LS7 intake?
Old Apr 25, 2007 | 11:56 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Power goal? 4.10's will be useless at big power levels.
