Procharger 4.5" IC and Coolant Reservoir Don't Play Nice
Those who have the 4.5" Intercoolers how did you get the passenger side to fit with the coolant reservoir in the way. The outlet side of the IC interferes with the tank that hangs below the battery. I don't think that the 3.5"'ers would make any difference.
Originally Posted by NASTYTRANSAM
I was able to loosen the bolts just enough to slid the res. over enough to make a better clearance....
Originally Posted by No Juice
How did you do that? The hole cut in the sheet metal is no bigger than the tank itself.
even the 3.5" ones have that problem. i used a tight radius 2.5" mandrel bend and a straight piece of silicone to connect them. It cleared up the squashing of the rubber hose and made things fit a little better. They're still quite friendly.
