F1A with Air Conditioning???
Old Apr 1, 2007 | 06:58 PM
speedracer5532's Avatar
Default F1A with Air Conditioning???
Has anyone actually been able to still run the A/C with a F1 in a F-body?
Old Apr 1, 2007 | 07:31 PM
HUNTER02SS's Avatar
All you have to do is move the radiator and condensor forward about an inch.
Old Apr 2, 2007 | 06:14 AM
Are you actually running a F1 series and have done it or helped someone do it? To come off of the supercharger with a 4 inch elbow you need to move the bottom of the radiator forward alot more than 1 inch. If I wanted to run just a half round air filter then yes half an inch would work.
Old Apr 2, 2007 | 09:58 AM
SLPHawk300's Avatar
it works on an LT1, i know that, and yes...i have it.
Old Apr 2, 2007 | 10:36 AM
YellowToy/A's Avatar
ttt any one else
Old Apr 2, 2007 | 12:01 PM
koji777's Avatar
F1 here, moved rad 1+ inches... running 4" 90 deg elbow.... tight but fine.
Old Apr 2, 2007 | 01:04 PM
TNTramair's Avatar
and you have to trim the support in that location as well.
Old Apr 2, 2007 | 01:25 PM
HUNTER02SS's Avatar
I forgot about that you have to also cut a small portion of the corner off the radiator support.It work's,seen it done and also helped have it done.
Old Apr 2, 2007 | 01:38 PM
OK thanks, I will try it out tonight.
