Fireball FI98x Turbo Build
Old Jul 29, 2009 | 07:58 AM
  #101
Fireball's Avatar
Originally Posted by Shawn @ VA Speed
it obviously never grounded out before,or it would have blown the fuse earlier-these are 2 totally separate problems
has to be a dead short to blow a 30A fuse...it was probably partially drawing down intermittantly. It didn't chafe itself sitting in my garage....started up and drove it in and went to restart later in the day and it blew the fuse
Old Jul 29, 2009 | 08:44 AM
  #102
NA$TY-TA's Avatar
Didnt it give you crap before y aput it on the trailer before ya left MIR??
Whens the next outing to see how she does now??
Old Jul 29, 2009 | 09:16 AM
  #103
Fireball's Avatar
it tried to start but I think the q16 vapor locked due to heat...
planned to go tonite, but rain is gonna put a damper on that idea
Old Jul 29, 2009 | 11:55 AM
  #104
NA$TY-TA's Avatar
well damn.... nice and hot down here.... not so sure on rain here. Weekend??
Old Jul 29, 2009 | 12:41 PM
  #105
Phil99vette's Avatar
7 Second Club
Looks like the weather isn't going to cooperate tonight. 75% chance of rain and 2250' DA.
Old Jul 29, 2009 | 03:59 PM
  #106
98Z28CobraKiller's Avatar
Restricted User
I dont know about how your weather forecasts work up there but here it rains everyday in the summer. The percentage indicates how much of the time it will be raining. I've driven my car about 5 times this summer because I am scared to get caught in the rain on MT drag radials and no A/C. You typically have to drive thru rain to get to the track and hope it's clear over there.
Old Aug 3, 2009 | 09:51 AM
  #107
ripmf666's Avatar
Very nice looking car you built there Fireball.Hope to see it run at Cecil one of these days.
Old Aug 13, 2009 | 08:25 AM
  #108
Fireball's Avatar
New round of updates...
changed to Phil's LS7 coils two weeks ago(to determine if I have a coil issue)...but found out the hard way not to run the crank trigger wires near coils...it don't like that and does interesting things when it fires 50* late
So this past week, I relocated the coils further away and changed to a grounded/shielded MSD crank trigger wire...hopefully this clears up the issues I had 2 weeks ago
Shawn also has a 4bar MAP sensor for me to change to...30 psi just ain't gettin it done
I'll probably be selling my GM 3bar MAP sensor soon
Old Sep 23, 2009 | 08:39 AM
  #109
Fireball's Avatar
updated this thread for archiving...
After fighting misfires and backfires all season,
had the injectors cleaned and switched back to C16
1st hit...spun 40' out.
2nd hit...lowered tire pressure 1/2 psi
car was FAAATTTTTTTTT on this pass...switched back to C16 fuel and A/F was in the 9.x:1 AFR the whole way down track
60ft-1.363
330ft-3.509
1/8-5.244
mph-142.52
1000ft-6.733
1/4-7.997
mph-177.88
Third hit...added more boost at launch and leaned it out some...car drove to the right at launch and got out the groove and spun ~50ft out...but I pedaled it and legged it thru the 1/4 for fueling data:
even spinning about 1.1 seconds into the run it went a 1.33 60ft ...biggest surprise is that it picked up 48 freaking mph out the back door (123.26 to 171.14 mph )
BUT
probably wasn't the wisest thing to do...hit some other parts of the map due to the spinning and it hurt something...didn't push water but oil got milky
7.99 vid
http://www.youtube.com/watch?v=L4LulA2kF2Y
Old Sep 23, 2009 | 09:15 AM
  #110
DrTurbo's Avatar
LS1TECH Sponsor
Wow....that sucker keeps getting faster. With it leaned out and running right, no reason it shouldn't go a 7.7@180 or more.
Old Sep 23, 2009 | 09:59 AM
  #111
bumpin_records's Avatar
Man i have to say i love the way your car leave. Like your cruising down the street.
Old Sep 23, 2009 | 04:09 PM
  #112
Gforce Engineering's Avatar
Wow, sounds like you have (had) it worked out.
Keep up the good work, I've been watching your build from day one
Old Sep 23, 2009 | 04:47 PM
  #113
MIGHTYMOUSE's Avatar
holy shhh!
dont you hate it when a rackety *** dragster f's up a nice quiet badass turbo car video?
Old Oct 9, 2009 | 12:37 PM
  #114
Fireball's Avatar
closing this thread...I'll be starting all over with a revised turbo setup...
https://ls1tech.com/forums/forced-in...ld-thread.html
