Fireball FI98x Turbo Build
Old Jun 6, 2009 | 08:23 AM
  #61
Phil99vette's Avatar
7 Second Club
Originally Posted by Fireball
Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All-Fuh-Q-All
And this is coming from Mr. I want to switch to Alcohol. Good luck today!
Old Jun 7, 2009 | 06:52 PM
  #62
Fireball's Avatar
slowly but surely making some progress...
Ran at the cecil streetcar shootout this past weekend (drag radial event). 1st qualifier yesterday...shook the tires pretty good at ~1.5 seconds in the run...ran a 5.63 @ 139 (look at the shake marks on the track )
http://home.comcast.net/~tfranklin55...ual1_small.wmv
1st round today, stepped it up quite a bit and ran a new best of 5.26 @ 141 but the other car ran a 5.16 we were dead even by incremental up to the 330' mark...made for a killer heads up race
60' 1.369
330' 3.511
1/8 5.261
mph 141.86
http://home.comcast.net/~tfranklin55...5p26_small.wmv
Old Jun 8, 2009 | 11:06 AM
  #63
DrTurbo's Avatar
LS1TECH Sponsor
60' 1.369
330' 3.511
1/8 5.261
mph 141.86
Nicely done.....that FI98X keeps pulling strong.
Old Jun 8, 2009 | 11:13 AM
  #64
98Z28CobraKiller's Avatar
Restricted User
Do you really need more turbo? I just saw a vid of a grand national going 7.9 @ 17X with a single GT47-88, 3450 race weight and stock style suspension.
How can they get so much power out of that little turbo? Why can't we?
Old Jun 8, 2009 | 11:14 AM
  #65
DrTurbo's Avatar
LS1TECH Sponsor
Its all about pressure ratio. Smaller cube motors run turbos more efficiently, though they take longer to spool them.
Old Jun 16, 2009 | 12:13 PM
  #66
Anonymous's Avatar
10 second playa
Fireball, Great thread, Very informative, thank you for sharing.
One thing though, you say the car is missing on top, do you think it is time to go with a distributor?
When I talked to one of the super fast LSX guy's down at Memphis, about why he went from individual coils to a distributer...
(Seemed to me like going backwards)
He told me that at high RPM and High power you need it.
You are right there. FWIW.
Old Jun 16, 2009 | 12:16 PM
  #67
Fireball's Avatar
we appear to have solved it. rich fuel mixtures coupled with overheating coils
knocked the dwell down some and leaned it out and it pulls to 8K cleanly now
Old Jul 5, 2009 | 04:56 PM
  #68
Phat69's Avatar
who sells the fuel pump drive mandrel that fits ls motors?
Old Jul 5, 2009 | 06:09 PM
  #69
Fireball's Avatar
it doesn't "fit" per say. its an ATI BBC drive mandrel that ATI modified their LS1 pulley to work with.
Old Jul 26, 2009 | 12:13 PM
  #70
Fireball's Avatar
Couple updates...been having constant issues with backfires still...so per BS3's advice we switched to an BS3 24-tooth external crank wheel and a virginia speed pickup bracket
Took it to MIR Friday night for 1/8 mile Drag Radial Racing...
First test hit...crank pickup with sporadically loosing tooth reference (originally setup per BS3 directions)...no real run made
1st qualifier...we adjusted the air gap on the sensor, no better, no real run made
2nd qualifier...adjusted the position, (cam-crank advance angle) and left the gap alone...fixed the issue, on a soft tune up went 5.26 @ 139.8 to qualify #7 out of 21. This was the most stable the boost has ever been on the car...hit 30 psi and held it throughout the run...the crank trigger fixed the sporadic boost issue
***BUT***
1st round...made a timing adjustment and had a small backfire on the 1-2 shift...was really rich at that point...lost the round 5.30 @ 139
Test hit...made another timing adjustment and a VE map adjustment and it spun a bit on launch and had another small backfire in 2nd gear...this time A/F was ok...WTF.
GEt home...unloaded the car and the fugger wouldn't start...after some diagnosis, the 30Amp BS3 coil fuse fell out when I pulled the weatherpack cover...and it was blown...looks like it had been working loose for quite some time and was restricting power to the coils Hope that was the issue since it seems everything is starting to work properly
Shawn is making me buy a 4-bar map sensor now so we can start getting after it
videos of the 2nd qual and first round:
http://home.comcast.net/~tfranklin55...runs_small.wmv
Old Jul 26, 2009 | 01:09 PM
  #71
98Camarod's Avatar
Are you goin after Phil or what Hopefully that was the issue and you can actually make a good run
Old Jul 26, 2009 | 01:12 PM
  #72
Fireball's Avatar
I'm 200 lbs heavier, 72 cubic inches and 8mm turbo inlet smaller than Phil's car...how can I compete with that
Old Jul 26, 2009 | 01:14 PM
  #73
98Camarod's Avatar
Go on a diet and get a bigger turbo, that should solve it
You are givin a hell of a helluva go at it
Old Jul 26, 2009 | 03:06 PM
  #74
7 Second Club
Here we go. My turd is still .32 slower than a certain 390ci turbo mustang so that whole cubic inch thing is out the window. We need to start hitting it harder earlier and it will come around. We need to find the absolute max RPM/boost you can leave at, then start playing with the ramp rates. I know its harder to do it with a smaller motor but its going to get done.
Old Jul 26, 2009 | 03:41 PM
  #75
Fireball's Avatar
Houston...we got a problem...got a bad truck coil it appears...put new fuse in, blew immediately,
that BS3 fuse is for Wideband and for coils. Unplugged wideband, new fuse and it blew immediately, plug in wideband and undo both coil connectors, and new fuse is good...Phil is sending me his old set of LS7 coils to try
Old Jul 26, 2009 | 04:13 PM
  #76
camscam02's Avatar
So I have been thinking and watching you guys go at this for a while. Flying I must say, thinfg is real nice.
It seems to me you are out manned in the outlaw radial events, why not throw a 275 on it and go be the number 1 contender? seems like it would be way more competitive for you and maybe a little more fun?
Old Jul 26, 2009 | 05:46 PM
  #77
Fireball's Avatar
overturboed for 275
Old Jul 26, 2009 | 07:41 PM
  #78
camscam02's Avatar
overturboed for 275
Yeah I figured that out after I clicked reply. Sorry for my stupidness. reducer anyone!?!?
Car fawkin flys though. You have got to be proud. Keep up the great work. Im just a slow ole' nitrous guy anyway.
Old Jul 26, 2009 | 09:13 PM
  #79
'Trust''s Avatar
That is sick nasty (I don't even know what that means, but you get the idea).
Old Jul 27, 2009 | 06:08 AM
  #80
Fireball's Avatar
most 275 rules around here only allow a true 88 (if they allow a turbo at all), so sleeves are out...
Shawn just wants to turn up the **** more...we need a 4-bar map though
