my 02 camaro sts project buildup progress--(pic)-
-You need to get 90* adapters coming off the oil pump. With the pump situated under the rear pass seat its hard to angle the hose unless it connect up at 90*.
-Are you connecting the oil pump up the same time you mount the turbo? Just make sure they dont do one and not the other.
-Thats a check valve in the feed right?
-Dont drive with 42lb injectors untuned. Youll be spraying too much fuel and wash the cylinders. Install them in the parking lot of the tuner.
-Take out the spring in your wastegate so that the car doesnt make any boost.
-What is the box in the top left of the photo with the -4an fittings?
All that damn oil stuff. I spent soooooo much time, driving, etc, etc figuring that crap out. I said screw it and did it the easy way. Don't remember what that is now
.I think it was mostly the stock STS stuff...a few fittings here, a few connectors there and a whatchamacallit in the middle. It's basically just a couple of feet from my flux capacitor...
right now i am mock fitting the charge pipe. you cant really see in the pic but it is going over the axle. and my side skirts hide the pipe really nice.
im going for max ground clearance. hahah i ALMOST finished but i was short a 90 degree bend under the engine as you can see. i have to find someone that will weld aluminum and then paint the pipes black.
I CANT FIND THE VBAND CLAMP FOR THE DOWN PIPE anywhere, someone please help !
Did you have to modify any of those charge pipes (as in cut or bend)? It looks like you literally just played a game of legos and snapped them right up. Post up some more pics of the wastegate pipe and I-pipe.
Four Qs:
I thought I sent you a vband??
What kind of wastegate did you get?
And why did you go over the axle for charge pipe?
What pieces came in that box (i guess which did you use)
keep up the good work
javenger i ordered 90 bends, 45 bends, and straits, i also have 90,45, and strait couplers. i just cut a few pipes, but the rest is just legoing them together lol.
you did send me a vband, but its too small, and the shop tryed to order one, n it was too big. so right now im just kinda stuck.
i am using a tial 38mm wastegate, and i just feel that over the axle is cleaner, stealthier, and better ground clearance.
ill take more pics this afternoon, ima try to get all the oiling set up
notice how I 45 up right away.
no scraping and the front of my car is lowered.
been that way for 2 years now
the 45 has hit the ground once when the car bottomed out on a wacky dip in the road.
your magic ball might be right 5-10 years down the road, but so far so good.
heres the problem
help help help help help!!!
heres what happened, i spent the day installing my turbo, i wanted the turbo mounted, and all oiling done. so i taped in next to the oil filter, and hooked up the 4an line... started the car, oil streamed through like normal. so i hooked it to the top of the turbo. then i set up the oil pump. set it up to come on with the fuel pump, i turn the key to on, and i hear it prime like normal. so i run the line to the oil cap n such.
so bascially everything is setup except the charge pipe isnt going into the throttle body just yet, its just sitting there under the car. i go to start it with the turbo and wastegate etc mounted. and i look under the car and WATER is flying through the exhaust. leaving a big puddle on the ground. i have no idea whats going on???
anyone have ideas???
i had something similar happen to me awhile back... but it was only little trickles of water that were dripping out of the exhaust pipe after the turbo. i was already tuned and everything though, but it tripped me out...
also, that silicone elbow coming off the turbo is making me worried. I have a small problem when i go into boost, and the pipe going over the axle pressurizes, it flexes and hits the rear end and part of the tunnel underneath. I can hear it happen when the turbo spools. I assume you might have the same problem with that elbow.... but just lookin out for ya!! eveything looks awesome though!
