my 02 camaro sts project buildup progress--(pic)-
what i have:
-sts turbo
-o2 sims
-sts instructions
-02 bungs, exhaust wrap
-gutted cats(in the mail)
-wideband airfuel (in the mail)
-walbro 225 fuel pump
-42 pound injectors
-sts oil pump
-ls6 pcv setup
-90degree elbows, MAF relocators
-sts switch
-air filters, breather, hardware
what i need:
-waste gate
-oil return (either cap or tap into pan)
-lots of piping
-a good shop to tune
i want to have this done before my summer starts, its been pretty fun trying to find good deals and gathering up all the parts. i will post a FINAL price of every dollar that went into this, to see if doing it yourself is really cheaper than just buying the complete kit. any opinions or comments???
I would add a blow off valve, vacuum manifold, intercooler, and few gauges.
I didnt know you were actually doing a rear mount turbo.
Few questions:
What turbo is that?
Why the LS6 valley cover?
How you doing PCV setup?
Where you located?
and some tips:
-get McMaster Carr Vac Manifold to go into the brake booster. I got the 3 port which can do the BOV, WG, and boost guage. You can get one with 4 ports if you wanna do a vacuum FPR.
-find a local exhaust shop for the charge piping. Ive seen guys spend upwards of $300+ just for some bends and straight pipes. You'd be surprised what a local shop charges for cheap 2.25" piping. I did a V6 rear mount for $80 for the entire charge piping and downpipe.
-Go under the rear axle for charge piping.
-keep stock manifolds and wrap it up to the turbo.
-ebay has plenty of different ICs for cheap. Im personally gonna cut the bumper and foam and run a 4" up front. Theres other guys that have made a pusher fan setup that mounts perpendicular to radiator.
I think for the amount of time and effort spend in a DIY setup you'll get pretty close to a nice TRT kit. It all depends on what your time is worth. Some prefer not to run around test fitting stuff and crossing fingers so a kit works good for them. Either way goodluck
btw were you still interested in that vband clamp?
I am +1 for going to an exhaust shop and having them do the hot side work. I had 3" dp back exhaust done for $125 even, bends and all.
Best of luck with it.
Few questions:
What turbo is that?
I just did my PCV system this weekend and it turned out great. Here is a simple and effective was to setup the PCV system on an STS setup.
- cap off intake manifold, TB, passender side valve cover ports.
- Add a breather (thunder racing) where the oil fill cap goes.
- run the oil return line to the rear port on the drivers side valve cover. I took the quick release fitting off and connected the fitting from the pcv that plugs in the drivers side valve cover, fits perfect. This seems to be a really clean setup that works effective.
Im currently setting up my PCV like you said.
I cant remem if I've asked already but are you running a check valve (if so, where?) and is the original PCV valve still there or is it just the plugs and return line?
eatinstang post up some pics, i wanna see
Heres my new pcv system.
2nd pic is the return line that now goes to the drivers side valve cover.
Every thing else is capped off.
You could run the 2 ports on the passenger side to a cc w/a breather to help seperate the oil. The setup I have now works great and looks a lot cleaner then running a cc and all the pcv lines.
umm has anyone here bought a kit from sts themselves?? pm me if youd like to help me out with ordering some "replacement" parts from them
