exhaust wrap and stainless exhaust (fatigue and fail)
ok, got my sts kit and I have wrapped my exhaust up to the y-pipe because I talked to a friend that did a race team and they wrapped everything, and after 2 races they could squeeze the exhaust and it would just crumble with their hands.
now what i'm wondering is i have kooks 1 3/4 stainless steel exhaust along with the stainless y-pipe w/cats, yes i said it. i believe that i will not wrap the area around the cat, as it can only get soo hot.
what i'm wondering is will my exhaust (if i wrap the headers and all) crumble like described above eventually??
there is a temperature that the stainless can be bent and moved at and stainless does fatigue under sustained high temps as most do all things.
I have easily seen 1200+ degrees exhaust temp
LS1 Tech Administrator
Moved from advanced tech.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Originally Posted by JAvenger007
interested in this too. Who's had wrap on for a long time?
![Lurk](https://ls1tech.com/forums/images/smilies3/lurk.gif)
Sawzall and Welder Mod
I had a wrapped set of mild steel headers on my 67 back in 99 that I pulled off to get ceramic coated, and when the coating shop tried to sandblast them the blaster blew right through the steel. Stainless should be OK though. If you're really picky have the pipes coated first, then wrap them. The coating inside the pipe will keep some of the heat from ever reaching the metal.
thats what i'm wondering about... just on and off heat changes from 1300+degrees or so down to ~750 and then back up ... etc.
just wondered if anyone had exhaust problems from wrapping over a long period of time
Originally Posted by SRZ
Bob from EPP sells some good wrap from what I've been told. Might want to ask him.
**buying rearend and such soon
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
I had a GTP and I wrapped the crossover and flex pipe with some of the cloth type wrap. The flex pipe was right where the cat-back started. I had it on SLP headers (Stainless). It was on there for two winters driven in all weather and never had an issue. I could see with mild steel, you might get moisture in there, and rust it through in no time.
-Geoff
-Geoff
