ST-series T4 turbo
Old Jun 29, 2007 | 05:20 PM
  #161
bandit1's Avatar
Originally Posted by DrTurbo
I would jump to the SX80. The ST80 turbine wheel is better suited to a smaller CI engine. Don't get me wrong it will outflow the GTS turbine wheel, but its still a little small for a big 408. The SX80 is even larger and more powerful.
Sounds good will it bolt up to my T4 flange?? If so can you send me a price and avalibility thanks so much
Old Jun 29, 2007 | 06:07 PM
  #162
NA$TY-TA's Avatar
Price is on there site..... just looked an hr ago..........
Old Jun 29, 2007 | 07:00 PM
  #163
ninetres's Avatar
I hope my ST80 boosts my 364ci to the moon because all of these new turbos make me want to second guess my choice.
Old Jun 29, 2007 | 07:58 PM
  #164
Dbluegoat's Avatar
i know its nuts.....soon as you get one there is already a bigger and badder turbo ready
Old Jun 30, 2007 | 06:02 PM
  #165
DrTurbo's Avatar
LS1TECH Sponsor
Its all about what you need though....no sense in getting something you may not need...
Old Jun 30, 2007 | 06:09 PM
  #166
stevieturbo's Avatar
I need a bigger wheel in my Vortech
Old Jul 2, 2007 | 10:17 AM
  #167
DrTurbo's Avatar
LS1TECH Sponsor
Yes its a standard T4 flange piece.
Old Jul 2, 2007 | 07:45 PM
  #168
ninetres's Avatar
*knock knock knock* UH OH
Old Jul 2, 2007 | 10:46 PM
  #169
Dbluegoat's Avatar
is it wrong to fondle your new turbo for several days as it sits and looks at you on your desk?
haha....my wife thinks I am strange.
you get yours yet ninetres?
Old Jul 2, 2007 | 11:11 PM
  #170
phildo's Avatar
Hey Doc, I have been trying to get in touch. I need a t-4 turbo for a 402. What is the biggest ,baddest one you recommend? What is the wait time to get one?
I know I should go t-6. I will switch to a t-6 over the winter. I don't want to down the car right now.
Thanks
Old Jul 3, 2007 | 12:33 AM
  #171
ninetres's Avatar
Yep! WAY BIGGER than my 76gts
How is the shaft play on yours? Mine seems to have a good bit more than my T76gts. Something also rubs in the exhaust housing if the turbo is held at a certain angle and I spin the wheel.
I'll give you guys (FI.com) a ring tomorrow to discuss if it is normal or mine needs a little adjustment.
Old Jul 3, 2007 | 10:06 AM
  #172
DrTurbo's Avatar
LS1TECH Sponsor
The shaft play is due to no oil. The turbos are only assembled in lube. Once you fire it up with oild pressure it will tighten immediately. That is why they call them floating bearings. As for the turbine housing....let us know asap if its debris from packing or not.
Old Jul 3, 2007 | 11:18 AM
  #173
NA$TY-TA's Avatar
Any word on my cover.... before the Holiday gets here?????
Kyle
Edit: Id like to keep my cover silver if thats possible...
Old Jul 15, 2007 | 09:34 PM
  #174
Earl H's Avatar
Anymore info on the "E" Cover stuff?
Old Jul 16, 2007 | 02:54 PM
  #175
DrTurbo's Avatar
LS1TECH Sponsor
Being worked on as we speak. ALOT of machine work has to be done to get the ETT to work with a standard E-cover.
Old Jul 16, 2007 | 03:56 PM
  #176
Earl H's Avatar
Any flow or hp estimates to speak of? What is the ETT wheel size range that can fit in the E Cover?
Old Jul 16, 2007 | 04:53 PM
  #177
DrTurbo's Avatar
LS1TECH Sponsor
Largest so far is 66mm. The 66mm ETT wheel will flow 78-79lbs/min . Compare that to a standard 66mm wheel.
http://www.forcedinductions.com/compressormaps.htm
Old Jul 16, 2007 | 06:47 PM
  #178
slowbrakiller's Avatar
is 72 and 79 really that big of difference?
Old Jul 16, 2007 | 06:48 PM
  #179
Earl H's Avatar
Will it flow that amount in a small E Cover? When will they be available? Any idea on pricing?
Old Jul 16, 2007 | 06:50 PM
  #180
DrTurbo's Avatar
LS1TECH Sponsor
About 70+ hp per turbo.......
