HKS Bov users inside
Old Apr 27, 2003 | 08:44 AM
GMC SKI's Avatar
Default HKS Bov users inside
I have a few questions on the HKS BOV .
I have the ssqv version installed in my truck
What do i do to tune this thing in ?
also what is it supposed to sound like when it blows off so far it sound like a fluttering
noise when it goes off I'm not sure that it's dialed in.
any ideas or input would help
jim
Old Apr 27, 2003 | 01:21 PM
BIGBOS's Avatar
Default Re: HKS Bov users inside
I recently bought one of these for my upcoming project....
Is it a constant fluttering noise, or does it happen when you let off the gas and decel?
Old Apr 27, 2003 | 01:47 PM
GMC SKI's Avatar
It flutters when i let off the gas . for Example i rev it on park and it sort of flutter open not like the ATI valve at all
I gotta get the tech 2 on it check how things are i put a smaller pulley on it 3.6"
not the 4" it came with don't wanna blow any thing up
gotta make sure i have enough fuel to cover the extra boost
gonna go out tonite and do some tuning
jim
Old Apr 27, 2003 | 02:08 PM
Unreal's Avatar
Fluttering means the spring is too stiff and its not actuating properly. Loosen the adjustment. When you let off at full boost, it should make a nice "whoosh" sound. If you set it too loose, it will leak boost. The HKS in general works good on higher boost applications. Like the Tial and other "racing" bov, it flutters and doesn't full actuate at lower boost levels. If you adjust it down and it still flutters, run more boost . Other option is to switch to a valve designed for lower boost applications.
Old Apr 27, 2003 | 10:47 PM
OOsilverado's Avatar
this isnt related to your problem, but i was wondering if the Procharger kit puts the MAF before or after the blower? thanks
As far as your problem is concerned, i think Unreal is 100% right
Old Apr 28, 2003 | 07:53 AM
GMC SKI's Avatar
the Procharger kit retains the stock location for the Maff sensor
so after the charger
jim
Old Apr 28, 2003 | 05:13 PM
MIGHTYMOUSE's Avatar
my sskqv makes a way high pitched ssheew! when i come out of a good amount of boost..
to adjust it, back off the screw all the way and tighten it until it just barely stops leaking air past it.
Old Apr 28, 2003 | 05:48 PM
Unreal's Avatar
You want it to stop leaking at the maximum boost you run, other wise it will leak boost. So if you run 10psi, pressurize your intake to 10-11psi and adjust the BOV so it doesn't leak.
