Supercharged LT1... what spark plugs and gap do you guys prefer??
LS1TECH Sponsor
Originally Posted by onefastbird95
Have you run 9psi on your stock bottom end or did you build it up? I have been told 9psi is a bit much for stock, people say to bump it down a couple psi... not sure the best route to go
100 Stock bottom end, haven't even had the heads or intake off yet. Like Call911 said, you need a good tune. I am even running a little leaner than most tune at, she is at 12.0 across the board. If the car sits for awhile, I will pump the fuel out and put fresh in. I run 93 with Torco Accelerator additive, about a can to every 10 gal.
Before the supercharger, I did a dyno test with old fuel and then new fuel...19 hp. I got 14 back with NOS octane boost. And by the way, you can't keep the Torco stuff from season to season....she goes bad!!
Fuel system, no matter what boost....get a good pump in there.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
LS1TECH Sponsor
Originally Posted by CALL911
9psi is about the most I would run. Even with 9#'s, you better have a top notch fuel system, along with either a large intercooler or a methanol injection setup, not to mention a great tune.
Safely with a stock bottom end, and everything I listed above, I wouldn't go above 6#'s unless you are ready to buy a new block if the stock one goes.
Just my .02 cents. Everyone has their own opinion on this.
__________________
LS1TECH Sponsor
pmed you back to get a little more info! thanks for all advice, I am trying to read up and learn as much as I can while I am installing this supercharger. It is all new to me and I want to educate myself the best possibly way I can!
__________________
