Supercharged LT1... what spark plugs and gap do you guys prefer??
Old 05-16-2007, 03:50 PM
onefastbird95's Avatar
Default Supercharged LT1... what spark plugs and gap do you guys prefer??
I am putting a vortech s-trim on my 95 lt1 formula. I have done some research and found some people put ngk tr6 and some put autolite 104 on there lt1's, but I have not gotten any deffinate answers... also there are different opinions on gapping. Vortech told me 40-42 would be the correct gap. I am also wihsing to replace the plug wires with some stock replacements. Please let me know your guys opinions so I can make the best possible selection.
Old 05-16-2007, 09:55 PM
anyone?
Old 05-16-2007, 11:14 PM
CALL911's Avatar
It depends on your boost level. If you are over 13#'s of boost, you should run an Autolite 103. Almost all guys are gapping at .35, although some go a little smaller like .32
I have heard some guys having issues with the NGK plugs.
Old 05-17-2007, 01:47 AM
SRZ
SRZ's Avatar
TR6 gapped @ .030. CALL911 I didn't know autolite 103's were cold enough. Hmm I've got 2 sets laying around as spares.
Old 05-17-2007, 02:08 AM
I am going to be running right around 9#'s of boost so would you guys recommend the autolite 104? or another plug? I also hear mixed reactions on plug wires... mine have 40k on them so they need replaced and I was thinking a basic replacement plug wire would work, any opinions on that?
Old 05-17-2007, 02:10 AM
what is going to be the difference from choosing the autolite 103 and 104?
Old 05-17-2007, 08:42 AM
Fire67's Avatar
Sounds like your motor is stock... With 9psi. Definitely upgrade your plug wires, the stockers and cheap stock replacements suck.
I ran TR6ix's in my stock motor with 10psi at .035
Now Im running Autolite Iridium plugs gapped at .024
Old 05-17-2007, 12:29 PM
if I decide to go the autolite route which autolite would work best with the stock motor and 9psi?
Old 05-17-2007, 01:12 PM
Fire67's Avatar
Not sure of the autolite part numbers, but you'll need to go 1 heat range colder than stock. Im running 2 heat ranges colder but my engine is far from stock and we're maxing the blower out.
Old 05-17-2007, 04:05 PM
Yeah I was told to run 1-2 heat ranges colder than stock, I am prob going to pick up some autolites but don't know for sure yet if the 104 is what I want for a near stock motor with 9psi. Hopefully someone who has experience with the autolites will chime in!
Old 05-17-2007, 05:06 PM
CALL911's Avatar
Not sure between the 103's and the 104's. For my boost level, I know the 103's are perfect (15#'s), but not sure if it would still be good for your boost level.
Old 05-17-2007, 10:41 PM
Yeah for some reason I thought I remembered seeing seeing guys would use the 104's on superchargers that produced around 6-8 psi, but still waiting to have that confirmed by someone who has tryed them out and can tell me the best bet for 9psi
Old 05-18-2007, 08:08 AM
LS1TECH Sponsor
Jon@BruteSpeed's Avatar
I have been running Champion RS12YC for the last 5 yrs. I am also at 9lbs on my LT1 and my ETs show the engine loves them. If you are not a Champion fan you could cross reference these.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old 05-18-2007, 08:09 AM
LS1TECH Sponsor
Also, don't gap them any larger than .035.
__________________
Old 05-18-2007, 08:30 AM
Fire67's Avatar
Call911- You will only need 1 heat range colder. NGK TR6 is one part# I positively know. If you go to Advance auto parts or AutoZone I KNOW they can cross reference it.
2 heat ranges will be too cold for your setup.
Old 05-18-2007, 08:34 AM
burnzilla's Avatar
On a stock internal LT1?
I would be looking at some forged rotating assembly kits.
Old 05-18-2007, 08:40 AM
LS1TECH Sponsor
That is what I have run since 02
__________________
Old 05-18-2007, 03:18 PM
CALL911's Avatar
I know for a fact that Autolite 103's are perfect for my boost setting. This has been proven on several similar boosted cars I know, and was reccomended by my tuner, until he found out I had AFR heads, and that the 103's don't have the gasketed seal I need for my heads.
I will be running Autolite 3922's in my car this year.
Old 05-18-2007, 04:24 PM
Have you run 9psi on your stock bottom end or did you build it up? I have been told 9psi is a bit much for stock, people say to bump it down a couple psi... not sure the best route to go
Old 05-18-2007, 04:31 PM
CALL911's Avatar
9psi is about the most I would run. Even with 9#'s, you better have a top notch fuel system, along with either a large intercooler or a methanol injection setup, not to mention a great tune.
Safely with a stock bottom end, and everything I listed above, I wouldn't go above 6#'s unless you are ready to buy a new block if the stock one goes.
Just my .02 cents. Everyone has their own opinion on this.
Quick Reply: Supercharged LT1... what spark plugs and gap do you guys prefer??
