turbo cam selection (search is down)
Old Jun 3, 2007 | 09:34 PM
ALL UC2's Avatar
im no expert on this, but i have been doing some research and this is what i have found
mild turbo setup you want about a 6 degree reverse split. bigger isnt always better. duration is more important that lift is.
billy bad *** turbo setup= single pattern cam.
lsa isnt as important as overlap is. there is a formula on how to figure overlap, but i cant find it. maybe someone will chime in on that.
everyone says that the ls6 cam is great, but i want something that is choppy at idle, soooo.... that isnt going to work.
if i am wrong on any of this someone please correct me on it.
i have also noticed that alot of people have different opinions on what works and what dont.
Old Jun 3, 2007 | 09:41 PM
ALL UC2's Avatar
Add the intake and exhaust durations
Divide the results by 4
Subtract the LSA
Multiply the results by 2
_________________
here is the formula for overlap.
less is more, you want something in the negative i think
Old Jun 3, 2007 | 10:05 PM
engineermike's Avatar
I don't think this is proven. There's a guy over on turbomustangs.com that just put a much larger cam in his car (from 226/226 to 24x) and it gained a bunch of power. Also, I'm a firm DISbelieve in the whole reverse-split thing, as you can see from my 224/236 cam.
Mike
Old Jun 3, 2007 | 10:15 PM
ta02zx10r's Avatar
Hey thanks for the info guys I really do appreciate your input and time. I would actually like to make this a turbo cam discussion thread since I do believe that we actually haven't had one on the forums here. Correct me if I'm wrong since I can't use the search anyway lol. Thanks again guys. I'll try to post up tommorrow with my thoughts (whether they are worth anything or not) when I have time. Thanks again
Chris
Old Jun 3, 2007 | 10:35 PM
ninetres's Avatar
Mike
How is your spool?
What kind of tranny and rear set-up do you have?
Old Jun 4, 2007 | 01:36 AM
99Z28LS1's Avatar
Originally Posted by JAvenger007
huh?
from your vid i thought your cam had a very nice lope to it too.
its only like that on the 1st start in the morning, rattles a little and calms down, but keeps the whistling to a constant
Originally Posted by bhz28
what are the spec of your cam 99Z28LS1?
228/228 .588 .588 115LSA mated with patriot dual springs and hardened rods for 6500rpm of BOOOST!
Old Jun 4, 2007 | 01:40 AM
99Z28LS1's Avatar
i have read that tons of people use the LS6 cam for a S/C set-up and work, but not many will agree that it will for a turbo set up
Old Jun 4, 2007 | 01:47 AM
2000 Tran Zam's Avatar
well my cam is a 408/91mm setup and its a reverse split with 6 degrees...
Old Jun 4, 2007 | 06:03 AM
Originally Posted by ninetres
How is your spool?
Hard to tell with an auto. I can tell you that the converter flashes to about 3000 on motor and that's enough to get the turbo going. However, as the turbo spools up, the converter flash goes up to 4400 or so.
TH350, Vigilante, 9" with 3.00's. 388 LT1, 224/236 cam, T76GTS turbo at 17 psi, 146 mph at full weight.
Mike
Old Jun 4, 2007 | 08:34 PM
00WHITETA's Avatar
Which would be a better cam the trt cam or the epp cam? Im wondering might be buying one or the other in the next couple of weeks!!!!!
Thanks,
Jimmy
Old Jun 4, 2007 | 08:53 PM
trtturbo's Avatar
guys, we have played with a few different cams, including some reverse split. The cam 99z28ls1 has is pretty mild, especially compared to the epp cam. We change specs depending on the motor. The cam is nothing crazy, but it does work very well on a mild boost 346; better than a reverse split on a similar motor.
Old Jun 4, 2007 | 10:19 PM
  #32
ALL UC2's Avatar
keep it coming. shows what i know about this subject. freaking internet, how the hell are you supposed to know what is right and what isnt??????
can someone that is an expert on this stuff give us and explination on what works and what doesnt and WHY????? there has to be someone on here that can give this info
Old Jun 5, 2007 | 06:21 AM
  #33
CHAMRA1's Avatar
I have a 408 Twin Garrett Turbo .
Its an Auto in a 4 door Commodore Sedan , ( daily Driven).
I'm in Australia for those that don't know what a commodore is .
What cam would you guys recomend for my setup ?
Old Jun 5, 2007 | 07:55 AM
  #34
The deal is that very few have done true turbo cam tests and they aren't releasing the results. Cam Motion has not done this testing.
The general rules that have worked for me are:
- Choose IVC based on rpm range desired. Rpm range should match that which the turbo can support. For instance, a 408 with a T61 isn't going to make peak power at 7000 rpm regardless of the cam.
- EVC should be IVC + 5 to 10 deg. This will match up the exhaust and intake rpm ranges reasonably well.
- Overlap has not shown to be bad for power in a turbo application. Choose the amount of overlap based on desired idle quality. I have 5 deg of overlap and it works well with a pretty poor backpressure ratio (17 psi boost and 33 psi backpressure). I'm sure there's a limit to this, but I'm not sure anyone has found it with our baby street cams.
Mike
Old Jun 5, 2007 | 03:01 PM
  #35
99Z28LS1's Avatar
my cam is a mild cam for a built motor, but does the job for my little non-built bottom end 346, i like it, thats my story and im stickin to it
Old Jun 5, 2007 | 10:11 PM
  #36
ALL UC2's Avatar
Mike
how do you figure out how much backpressure that you have???
anyone tried a hotcam with a turbo setup????? i know ls6 cams are popular but never seen a hotcam. im wanting a big thumpy bump idle but dont want something that is going to hurt performance.
Old Jun 5, 2007 | 10:51 PM
  #37
Big Geek's Avatar
Here is some great reading regarding turbo camshafts. http://www.turbochargedpower.com/Camshafts.htm
Jim C.
Old Jun 6, 2007 | 06:00 AM
  #38
You measure it with a gauge.
Yes. I wouldn't use that cam, though, due to the lazy ramps.
Old Jun 11, 2007 | 08:23 PM
  #39
00WHITETA's Avatar
Got an up date on the epp cam I was told by my tuner that cam would not work for a turbo car all that well. He told me it would be a dog on the low end and drive bad. Might work for a full race car turbo car with lots of power, but not what I got a weekend warrior. Not trying to hate on epp by no means they might make good products I have no idea. Just sharing with yall what I was told.
Jimmy
