Will the first LT1 in the 8's also be the first to the 7's???
Old Aug 8, 2007 | 08:20 PM
  #101
T/A KID's Avatar
Guys kinda of Off subject, but I see Chris's car is using AN fittings on the waterpump. I have a Griffin Rad coming and I had them do -16 up top and -20 on the bottom (-20 stuff is EXPENSIVE, lol).
Well I pulled the Alumnum piece out of the outlet so a -16 should setup in there pefect after welding, But I see how you guys "Flared" from the looks of it the Thermstat housing to accept the -20. Any thoughts??
Old Aug 8, 2007 | 09:10 PM
  #102
Z8'S's Avatar
I used a weld bung and counterbored the back side to fit over the neck.
Old Aug 9, 2007 | 08:56 AM
  #103
stroked30th's Avatar
I'm using a remote pump, and having the fittings welded to a motor plate. Using a Victor manifold and gonna plumb the fittings from the block into the thermostat crossover. From there you can buy SBC thermostat housings w/ the correct AN on them.
-12 from pump to block
-16 from the housing to radiator
Old Aug 9, 2007 | 12:38 PM
  #104
T/A KID's Avatar
Madman uses -12 and -16 but I would think for a Daily Driver I would need -16 and -20. A lot of the LS1 guys run the -20 stuff for daily application and Griffin recommended me the same??? I suppose a -12 and -16 would be fine for a race car though?? Whats your guys opinion?
Old Aug 9, 2007 | 01:13 PM
  #105
T/A KID's Avatar
Does anyone know if these would work?????
http://cgi.ebay.com/ebaymotors/NASCA...spagenameZWDVW
OR
I could get the excess hole welded up, if the angle would be the same with some longer bolts??? Most of you guys know more about this stuff any way.
Old Aug 9, 2007 | 01:21 PM
  #106
Mezeire has a wide selection. That's were I got mine from.
Old Aug 10, 2007 | 05:09 AM
  #107
ttcamaro's Avatar
running water through the turbos is night and day difference in oil temps. On the dyno i could make back to back passes without cooling down. Before after 1 full pull the oil needed to cool. I have alway ran a large front mount oil cooler as well and it still needed to cool after a pass
Old Aug 13, 2007 | 10:51 PM
  #108
Rob Valden's Avatar
Out of curiosity, why are you guys mounting the intercooler in front of the car? I would figure with having twins on the car none the less, the weight percentages are going to be crazy heavy up front? Not knocking just never saw anything like this.
Rob Valden
Old Aug 13, 2007 | 10:54 PM
  #109
Rob Valden's Avatar
Also who is giong to be tuning on this thing? Any reasons on mounting the turbos the way you did? No of alot of people who had a similar set up, wtih the inlet facing the way yours are, and > < this way as well. Both combo's had bad boost problems plus oiling malfunctions as well. If there is a pump on it, might not be as bad, just curious as well.
Rob
Old Aug 14, 2007 | 10:20 AM
  #110
qqwqeqwrqwqtq's Avatar
The intercooler placement was decided on for simplicity and symmetry. We did not feel moving the 30 or so pounds from in front of the radiator to behind the firewall was worth the amount of convoluted plumbing which would have resulted from it. (also considering the ease of between round maintenance). An air/air intercooler would have similar weight and a thumper sticking out of the nose would weigh much more.
We have built many vehicles with the exact same turbo placement and orientation with no oiling or boost problems to speak of. I can't think of any reason at all why there would be.
Old Aug 14, 2007 | 12:06 PM
  #111
Big Rick's Avatar
Talk about old School
Click here to see Video
Old Aug 14, 2007 | 02:50 PM
  #112
Silver 00 SS's Avatar
Old Aug 14, 2007 | 03:10 PM
  #113
FANTAZ28's Avatar
Moderator
not to mention many Drag radial races will only allow under hood intercoolers
Old Aug 14, 2007 | 05:40 PM
  #114
Rob Valden's Avatar
thats cool, just sort of curious...i new of a few people that had some problems with turbos mounted > < as long as you got it figured out and works then stick with it. best to you guys. never heard of the intercooler being mandated to be hunder the hoode either, but might be new?
Rob Valden
Old Aug 14, 2007 | 05:41 PM
  #115
Rob Valden's Avatar
i rmemeber these days! plus rick you suck! never like to call anybody anymore...my new **** is pretty much done. should be testing within the next month
Rob
Old Aug 14, 2007 | 06:00 PM
  #116
Nine Finger 02 Z28's Avatar
I have my intercooler in the nose of my car I get the same stuff from people all of the time...Nice setup...
Old Aug 14, 2007 | 07:24 PM
  #117
SP Motorsports's Avatar
just curious what radial races only allow under hood intercoolers..i have never heard that one..
Old Aug 14, 2007 | 09:14 PM
  #118
Brady's Avatar
LS1Tech Sponsor
Last year ORSCA EZ Street required under hood, or under dash (not visible in passenger compartment) intercoolers. They lifted that rule for '07- and I don't know of any other sanction that requires under hood intercoolers..
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old Aug 14, 2007 | 09:22 PM
  #119
LS1 SPEED's Avatar
THE CAR HAS LEFT THE BUILDING
Chris has a couple weeks of misc things to do and then it's ready to rock.
Old Aug 15, 2007 | 07:47 AM
  #120
LittleRedZ's Avatar
Originally Posted by CHRISPY
Is this the same Chris Sikora from years ago (mid 90s) that ran with the blower setup?
Man if so you are an OLD-TIMER hehe
Car and setup looks awesome man, congrats!!
This blower? http://www.youtube.com/watch?v=qB1jHeKFZa4
