How far would you push it?
Old Jun 10, 2007 | 05:18 PM
nossty1's Avatar
Default How far would you push it?
I am trying to figure out how far I can push my engine before I go to far.
I am going to be as complete as I can so if I miss something just let me know and I will put it on there.
Here goes.
Engine:
408" Iron Balanced, blue printed and assembled short block.
Eagle 4340 4.0" crankshaft,
Lunati 6.125" Pro Mod rods w/ ARP 2000 7/16" bolts,
Wiseco 4.030" forged Turbo Duty pistons -32cc dish,
Cam is 232/240 595/608 115lsa
C&A Fire Power rings
Federal Mogal 152M main brgs,
Clevite cb663 H rod brgs,
Dura Bond cam brgs,
ARP main studs
Roll master double roller timing set w/ torington bearing & nitrided gears.
LS1 Oil Pump LS6 Oil Pump ported & shimmed
Patriot stg 3 ls6 heads
Patriot duel valve spring kit
TSP hardend PRs
Ls6 intake manifold
Stock throttle body
Speed density tune
No more than 6500rpm.
Turbo kit:
PTK A2A kit with a t88
DP is 4in stepped down to 3in
Cutout after a couple feet of 3' pipe
Fuel system:
From EPP. Was told 900+rwhp has already been done with it.
Trans:
TH 400 RMVB
Trans brake
3500ish stall
Rear:
Stock right now but will be a 9" or dana 60 soon.
No meth yet. Pump gas.
How much boost/ power do you guys think it can handle.
Pump gas and race gas if ya can.
nossty1's Avatar
Fuel system is here if you wanna take a look
http://www.exoticperformanceplus.com...php?service=88
With 65lb injectors.
Old Jun 11, 2007 | 02:17 PM
nossty1's Avatar
Cmon, nobody has anything to say?
Old Jun 11, 2007 | 03:09 PM
ty_ty13's Avatar
7 Second Club
i wouldnt think twice about putting 1200hp down....
with those pistons (which are pretty much like mine except i had to flycut still) you are going to have a LOW compression.... around 8:1 with 72cc heads...
because of my flycutting and 72cc heads im at about 7.9:1 CR
Old Jun 11, 2007 | 04:11 PM
cablebandit's Avatar
pump 750 rwhp
c16....all that turbo will put out until it finally lifts the heads at around 900-1000rwhp
Old Jun 11, 2007 | 04:16 PM
nossty1's Avatar
Hopefully my L19 headsuds will do there job well.
With meth how far over 750rwhp do you think would be safe?
Old Jun 11, 2007 | 04:28 PM
93 + meth 850rwhp...L19s aint gonna keep the heads from warping between the studs but still should help a little. Just my opinion...hopefully some of the more experienced peeps will chime in
Old Jun 11, 2007 | 05:14 PM
DrTurbo's Avatar
LS1TECH Sponsor
I agree with this statement, L19's won't cut the movement out completely, but it will help.
Old Jun 11, 2007 | 06:02 PM
2000 Tran Zam's Avatar
with 65# inj's you will run out of fuel...
Im at 900rwhp more or less and i was around 90% I think.... im using 75#ers too...
Old Jun 11, 2007 | 06:40 PM
nossty1's Avatar
Thats what I thought about the L19s, but hey every little bit helps
^^^ Oh no!
