procharged now
Old Jun 16, 2007 | 11:14 AM
One Bad Z's Avatar
Default procharged now
Before:
3xxx stall, 10bolt w/4.10s, bolt-ons + cam
After:
3xxx stall, 9" w/3.70s, bolt-ons, cam, procharger at 5lbs. with conservative tune to save shortblock.
Old Jun 16, 2007 | 12:11 PM
1badsupersport's Avatar
Nice hope to be there soon as well, ditched my vortech for a little D1 kit I found. Also, love that zl1 like hood; looks mean as hell
Old Jun 17, 2007 | 08:44 PM
One Bad Z's Avatar
are my numbers where they should be? the auto takes a lot away on a dyno. ...and mine has seen better days. tranny fluid smells burnt.
Old Jun 17, 2007 | 10:56 PM
seems spot on for 5lbs through a stalled auto.
Old Jun 17, 2007 | 11:19 PM
99Z28LS1's Avatar
i think so too..... although im not a D1 guy, but that looks like it's at where it's supposed to be for 5psi in a stalled auto
Old Jun 18, 2007 | 12:19 AM
Subliminal Hit's Avatar
you can get it flushed with all new fluid for less then 100 bucks. Almost any shop has a trans flush machine nowadays. Might buy you some time before a rebuild.
Old Jul 29, 2007 | 07:14 PM
One Bad Z's Avatar
putting in a th350 in a couple weeks. got a tighter converter aswell. should see some better dyno #s and finally get to the track.
Old Jul 29, 2007 | 07:36 PM
DeltaT's Avatar
I think your numbers make sense too, for a 5# charge. Heading in the right direction!
Jim
Old Jul 29, 2007 | 08:47 PM
Slowhawk's Avatar
LS1Tech Sponsor
Looks good to me. I'm guessing the A/F readings on the dyno graph are wrong? If not it looks way too lean.
Old Jul 29, 2007 | 11:19 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
I'll say it this way: Its a good start for you. You will want more.
Old Jul 30, 2007 | 01:25 AM
TAwhore's Avatar
scott who installed it for ya, redline or your self?
also is this on a stock tranny?
-pong
Old Jul 30, 2007 | 02:16 AM
ZL1Killa's Avatar
good numbers for 5psi. you can see mine in my sig for my turbo setup. i need to grab an intercooler tho... hopefully soon
Old Jul 30, 2007 | 11:10 AM
venom ws7's Avatar
Great numbers man Through 9inch Stall and only 5psi.
Old Jul 30, 2007 | 12:05 PM
sevanseriesta's Avatar
is this a p1 or a d1
Old Jul 30, 2007 | 12:06 PM
One Bad Z's Avatar
-pong
redline did the install and dyno.
was with stock tranny that was crapping out
Old Sep 16, 2007 | 05:39 PM
One Bad Z's Avatar
p1sc-1
Old Sep 16, 2007 | 07:10 PM
Hawk108's Avatar
would you pm me what they charged for install?
Old Sep 16, 2007 | 07:27 PM
One Bad Z's Avatar
your inbox is full. was about $800 but had a alot of extras put on at same time.
